Need some advice on properly preparing my new(ish) car for 2 coats of ZFX enabled Z2. Car has white VAG paint in good condition i.e. very few swirls and scratches. I have both ZPC and ZAIO and I’m definitely going to use the AIO (to provide a good base for the Z2), only question is whether to use the ZPC as well as AIO and if it will really add anything to the finish?
Using ZPC will obviously remove any paint defects, and maybe strip the last of the dealer applied LSP. However I’m not too concerned about taking off whatever LSP is still there, as degrease, clay, de-iron and de-tar should take care of that.
I am thinking more using the paint cleaner as an abrasive for maximising the gloss and reflectivity of the white paint – will ZPC give me the edge in this sense?
Polish/AIO will be applied by DA and Hex pads if that helps.
Thanks,
R.
Thanks,
R.
