Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bilt Hamber
Old 03-07-2018, 02:12 PM   #1
jerseyman
Re Applying Dynax S50
My land rover defender was professionally chassis cavity injected with Dynax S50 7 years ago so I was considering topping it up with a fresh application myself.
Would I be best to try and clean the interior of the chassis first by spraying inside with a 10% Surfex HD Solution, and then rinsing through with a hose for ten minutes or so, letting it all dry thoroughly, and then reapply?
Or should I just reapply without any prep. The Landie is low mileage and has never been used off-road.
The answer might seem obvious, but I am slightly sceptical how much muck the Surfex HD/ Low pressure rinsing, would actually get rid of, and I do not really want to use the Pressure washer with a drain cleaner attachment approach.
Or indeed is the top-up needed at all?
jerseyman is offline   Reply With Quote
Old 03-07-2018, 02:54 PM   #2
biggriff
biggriff's Avatar
Get an endoscope attachment for your phone and take a look inside the body cavities first. They are £30 off amazon.
biggriff is offline   Reply With Quote
Old 03-07-2018, 04:13 PM   #3
jerseyman
Why didn't I think of that! Especially as I have an endoscope camera...
Old 09-07-2018, 08:22 AM   #4
I can't think of any good reason to put water inside the chassis. By all means have a check with the endoscope, good practice for any vehicle (especially one known to be at risk of rust) but I would just get some of the aerosols and long injector probes from BH and fizz some more protection in there.
Old 09-07-2018, 09:30 AM   #5
dave-
dave-'s Avatar
No you don't need to do that because they are probably as good as the day they done it
dave- is offline   Reply With Quote
The Following User Says Thank You to dave- For This Useful Post:
sm81 (14-07-2018)
Old 11-07-2018, 04:55 AM   #6
MaDMaXX
MaDMaXX's Avatar
I'd be curious to see the pics before you started anything, see how it's held up.
MaDMaXX is offline   Reply With Quote
Old 11-07-2018, 07:35 AM   #7
Can’t see any harm in topping it up - not sure if it’s required, but can’t see any issues.
But wouldn’t recommend trying to clean it out and certainly not putting water in....
