Old 27-05-2018, 01:31 PM   #1
Ben_W
Ben_W's Avatar
Wowos Crystal sealant.....odd reaction upon application
Guys, been trying out my new pads/compounds in the wife's car this morning.
Washed and clayed the bonnet, corrected using Menz 2200 and a Lake Country CCS orange cutting pad. Refined using a Lake Country white polishing pad. Wiped down with G-tec panel wipe.
Using a clean foam applicator, I'm applying the sealant to the bonnet as directed but immediately it goes an odd cloudy colour and is an absolute sod to remove. I'll try getting a pic in a minute as I've still to finish sealing the bonnet but anyone else had this?
It went onto my Golf fine. The only difference was I hadn't done any machining as it didn't need it.
Old 27-05-2018, 03:02 PM   #2
wish wash
wish wash's Avatar
Are you applying it in the shade and are the panels hot
Old 27-05-2018, 03:20 PM   #3
camerashy
'Detailing Devil'
camerashy's Avatar
My first thoughts
Old 27-05-2018, 03:53 PM   #4
Brian1612
Brian1612's Avatar
Likely the heat but I personally don't apply it this way either as it didn't work well for me. I basically use it like a qd on very small areas at a time, quick and easy.
Old 27-05-2018, 03:59 PM   #5
Ben_W
Ben_W's Avatar
Thanks guys.
Very very difficult to photo so I haven't any pics. Wasn't in the shade but panel temps weren't high, or at least I didn't think they were. Didn't feel anything other than very slightly warm.
Will try again with the car in the shade once panels have cooled further.
Old 27-05-2018, 09:05 PM   #6
Lexus-is250
Lexus-is250's Avatar
Done mine with this a few weeks ago on a warm day but I was slightly in the shade when I came to apply. Found it ok to use for my first time. I polished then used cleanser fluid to wipe down and it went on and came off no problem. Does suddenly start to dry though so small sections at a time.
Tried putting it on the step daughters car a few days after ( it's black ) in the heat after polishing it with Bilt Hamber cleanser polish and it didn t like it at all so had to give up.
The finish it gave mine was awesome I really like it. It's the first time I've seen the metallic in the paint properly.
Old 29-05-2018, 11:02 PM   #7
I find that applying it with a damp sponge applicator, then using that to apply to small areas (no more than 30cm x 30cm), then buffing off, works well. In cooler conditions you can probably get away with larger areas. The damp sponge seems to be the thing that makes the difference!
Old 30-05-2018, 03:21 AM   #8
BradleyW
BradleyW's Avatar
I'd go over each panel with panel wipe again and ensure everything has been removed. Shake the bottle of the sealant very well. Lightly mist the foam applicator. Wipe gently onto a cool clean panel. Work on a small section each time. Buff off immediately.
Old 30-05-2018, 03:52 AM   #9
Brian1612
Brian1612's Avatar
Don't think panel wipe will strip Crystal Sealant. The instructions do say to be careful on application as a machine polish is required to remove it.
Old 30-05-2018, 10:00 AM   #10
euge07
euge07's Avatar
I would suspect it doesn't like to sit on top of cleanser polish
I find the best way to apply is to bare paint after a good thorough ipa wipedown and spray a few mists onto a microfiber cloth, apply to panel and buff off immediately with a fresh microfiber- I have coated plenty of cars now with this method and never once had a problem, in fact i found it really easy to use, the beading and water behavior is really good from it
The Following User Says Thank You to euge07 For This Useful Post:
BareFacedGeek (06-12-2018)
