Old 11-01-2017, 09:47 PM   #1
stealthwolf
stealthwolf's Avatar
Emptying E140.3
The pictogram instructions with the nilfisk are a bit rubbish.
To set up before use: connect everything up, run water and squeeze trigger so water runs freely and THEN turn on power.
To put away: this is a bit more confusing but i think it looks like - turn off power, disconnect from tap, remove trigger and then turn power back on and run until dry.
Can anyone verify this please?
Old 11-01-2017, 10:16 PM   #2
neilmcl
I'd imagine it's like any other PW. Turn power off, water off then squeeze trigger to release pressure. Then disconnect.
neilmcl is online now   Reply With Quote
Old 11-01-2017, 10:21 PM   #3
shine247
shine247's Avatar
For my 140.2 I turn the water supply off. Then sqeeze the trigger with the power off to release all pressure. Then remove the water supply then pull the trigger and run for about 15 seconds to drain the pump.
Also remove any lance at the final stage to ensure the water has the fastest escape, I think that is the bit that is not clear.
shine247 is online now   Reply With Quote
Old 11-01-2017, 10:32 PM   #4
Alan W
Alan W's Avatar
Yes, but you should then power back up and run motor briefly to completely empty pump of water. Without running up again you will not empty the pump fully and hence why nilfisk state 'run until dry' as posted by stealthwolf above.
Alan W
stealthwolf (12-01-2017)
Old 11-01-2017, 10:40 PM   #5
neilmcl
Alan W
Yes, I just checked the instructions for the E140.3 and it does suggest releasing the pressure, disconnecting water supply and gun from hose then briefly switching the machine on again to pump out any residual water.
Does this just apply to the professional range or is this advice for the consumer models too?
Old 11-01-2017, 10:51 PM   #6
Alan W
Alan W's Avatar
It is also stated for my C120 and therefore would appear to apply to both consumer and professional models.
Alan W
Old 11-01-2017, 11:10 PM   #7
neilmcl
I should read the manual more clearly then, I've never done this before with my 3 year old C120.
Old 12-01-2017, 11:25 AM   #8
stealthwolf
Thanks for the reassurance. I was a bit unsure and was trying to read the instructions on my phone whilst out on the driveway.
With my c120 I used to leave the hose connected but turn the tap off and then run the PW until dry. This seemed to clear all the water out but I never knew if it accelerated the death of the machine. I didn't want to make the same mistake second time around.
Old 12-01-2017, 11:46 AM   #9
shine247
shine247's Avatar
Definitely do not leave the hose connected because it restricts the free flow of the motor, it will try and drain your hose as well. Also there is a fine line between draining the pump and it overheating, I sometimes do it twice, 10 seconds, do something else and then another 10 seconds. My be over cautious but why not?
The Following User Says Thank You to shine247 For This Useful Post:
Old 12-01-2017, 02:47 PM   #10
Alan W
Alan W's Avatar
I find 5 seconds is usually enough. You can watch for water exiting the outlet and switch off as soon as it stops.
You don't want to run it dry for too long, just long enough.
Alan W
