Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > in2Detailing
in2Detailing www.in2detailing.co.uk
| 01382 622565 | Price Match Promise TAC Systems - Bilt Hamber - Chemical Guys - Bouncers - Prima Car Care - Krystal Kleen Detail - Wheel Woolies - ViseeO Authorised Distributor
Old 27-09-2016, 09:11 AM   #1
In2detailing
DW Sponsor
In2detailing's Avatar
TAC System Questions Thread
Hi.
Hopefully this will be a good place to get all the TAC system questions in one place for people to refer to.
Will get it made into a sticky.
Imran
:driver
Discount Code DW10
In2detailing is online now   Reply With Quote
The Following User Says Thank You to In2detailing For This Useful Post:
Yellow Dave (27-09-2016)
Old 27-09-2016, 02:05 PM   #2
Yellow Dave
Yellow Dave's Avatar
What's the recommended dilution for ultra foam through a lance? Website says 10:1 but only 10ml?
Old 27-09-2016, 02:27 PM   #3
Yellow Dave
Is shinee wax polymer or waxed based? Is there anything in it that will interfere with a fussy wax or happy to sit on top
Old 27-09-2016, 03:06 PM   #4
In2detailing
DW Sponsor
For me personally when I use Ultra Foam, I will add a finger width at the bottom of the lance (about half an inch) and then top up with water. Approx that would be 35/40ml but that would give me multiple uses from the single 1 litre mixture. I then will adjust the nozzle at the top to give the correct foam thickness. It is recommended to use 1-2" but it really depends on how thick you like your foam. I have updated the site to give better instructions
Imran
Discount Code DW10
Old 27-09-2016, 03:10 PM   #5
In2detailing
DW Sponsor
Hi,
From my understanding it is a wax polymer, but I will double check.
I am not a massive wax person, only really use Bouncer's waxes to be honest. It has had no issues at all on top on any of the ones I have used it on (generally Check the Fleck or more recently Flawless).
Imran
Discount Code DW10
Old 31-01-2017, 11:25 PM   #6
Yellow Dave
Any more info on the paint cleaner?
http://www.in2detailing.co.uk/tac-sy...ner-150ml.html
Does it contain any oils or fillers or just a bare base?
Old 31-01-2017, 11:49 PM   #7
Moet1974
Great idea Imran. Happy to add my findings of the Tac products.
Old 01-02-2017, 08:50 AM   #8
In2detailing
DW Sponsor
Hi.
This one has no oils or fillers, just bare base.
Imran
Discount Code DW10
The Following 2 Users Say Thank You to In2detailing For This Useful Post:
Malakkastraat (16-12-2017), Yellow Dave (01-02-2017)
Old 06-02-2017, 11:19 PM   #9
squad55
squad55's Avatar
Hi,
How do you apply the zero iron paste? Can this be diluted or does it have to be spread on?
squad55 is offline   Reply With Quote
Old 07-02-2017, 12:08 AM   #10
In2detailing
DW Sponsor
Originally Posted by squad55 View Post
Hi,
Hi.
Iron Zero Paste is effectively concentrated Iron X for really stubborn areas where brake dust has built up over time and iron zero isn't strong enough.
You use the product neat, so straight out the bottle.
If it is on wheels, I normally squeeze a bit to the area and then if it is a larger area just lightly spread with a brush.
For bodywork you can you a sponge, like a foam applicator to apply the product to the target area.
Leave it to work, approx 5 mins and then rinse off thoroughly.
Hope that helps.
Imran
Discount Code DW10
