Old 25-05-2018, 07:29 AM   #1
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
BuffBrite Flamethrower Led Polishing Lights -
Now in stock at Cleanandshiny -@buffbriteproducts
Flamethrower LED Light For Machine Polishers is now available online and via our walk in detailing superstore. They are currently on an introductory offer of £69.95 for a limited time.
(rechargeable, one or two lights can be fitted to most polishers)
You can see the difference here -
The Buff Brite Flamethrower is an LED light for your machine polisher. Immediately see paint defects and the results of your correction.
Key Features:
•800 Lumen LED Light (rechargeable)
•Cool blue colour temperature
•3 different light modes - Bright, medium, strobe
•2200mAh battery, which has enough power for a day of work on one charge
What's included?
•1x LED light
•1x Buff Brite Arm with Anti Vibrational mount
•Attachment hardware for almost any polisher!
•Charging cable
•Instructions
https://www.cleanandshiny.co.uk/coll...hine-polishers
�� - 0330 22 33 777
Old 25-05-2018, 10:43 AM   #2
Kenan
Would this work outside in daylight?
Sent from my Mi A1 using Tapatalk
Kenan is offline   Reply With Quote
Old 25-05-2018, 11:09 AM   #3
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
I would imagine it would - the light is 800 lumen
Kenan (25-05-2018)
Old 25-05-2018, 01:12 PM   #4
Hereisphilly
Hereisphilly's Avatar
I'm struggling to see the point of these I'd in honest, but I'm prepared to be corrected
When you are polishing, the polish is on the paint so you can't see the defects while polishing
You check for correction when you remove the product, but at that point you're not holding the polisher and therefore this light
Or am I missing something?
Sent from my Pixel 2 XL using Tapatalk
The Following 3 Users Say Thank You to Hereisphilly For This Useful Post:
Brian1612 (26-05-2018), euge07 (30-05-2018), Yellow Dave (29-05-2018)
Old 25-05-2018, 01:29 PM   #5
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
Do you use lights at all when polishing ? - i.e a floodlight ? chances are you do ? they can throw light that doesn't show the paintwork swirls etc and have to be positioned all the time unless you have a light tunnel etc - this eliminates the need and puts light where you need it - highlights the paintwork further - the light is right at the point where you need it ? - they can be switched on and off while polishing but as you can see if the photo the enhance the paintwork to show swirls that don't look to be there under other lights
think you have to see them in action
Old 25-05-2018, 01:47 PM   #6
Hereisphilly
Oh yeah i absolutely do use floods and spot lights, but as soon as the polish is on the panel and you are polishing you cant see the defects (which is when you are holding the machine)
You put the machine down to remove via cloth, at which point you can then inspect the paint
At this point I don't have the machine in my hand so I am likely to pick up a smaller lighter more wieldy light rather than my polisher with a light strapped to it
The pics show a machine with a pad laid against the panel, but I cant see any polish anywhere which i think is key in all this
The Following 2 Users Say Thank You to Hereisphilly For This Useful Post:
Brian1612 (26-05-2018), Yellow Dave (29-05-2018)
Old 29-05-2018, 01:19 PM   #7
MBRuss
MBRuss's Avatar
Good spot - they conveniently omit the polish in all the pics. Who pushes their polisher around the car with a dry pad on it to inspect the paint?!
May still help if you're polishing in poor light, but probably no more than a head torch. Also means you risk banging the metal arm/torch into the car somewhere, such as the wing mirror etc.
Seems a bit of a fad, but who knows - many power tools come with built-in work lights these days.
*Edit - just noticed that in all the pics with 2 lights attached, the user isn't even able to hold the front grip. The guy in the pics has his hand on top of the polisher!
Old 29-05-2018, 04:53 PM   #8
Triggauk
YEY another overpriced piece of equipment you will buy and never use!!
Triggauk is offline   Reply With Quote
Old 29-05-2018, 09:15 PM   #9
Looks like the Star ship Enterprise
The only place I see it being useful is doing large bonnet or roof as for the rest of the car it's pretty useless
Old 29-05-2018, 10:04 PM   #10
fatdazza
I raised a similar query, when this "must have product" was featured.
http://www.detailingworld.co.uk/foru...d.php?t=405651
I now know where I am going wrong- I am using polish on my pad
I think I should stop using the polish and then I will be able to see clearly when I have achieved sufficient correction.
Hereisphilly (29-05-2018)
