Tools -Machine polishers, Pressure Washers, Detailing Equipment & Microfiber Sponsored by Detailed Clean : www.DetailedClean.co.uk Ė | Bilt Hamber | Dodo Juice | Nanolex | Sonus | Wolfs Chemicals + More | Loyalty Scheme Discounts |
Old 28-05-2018, 11:29 AM   #1
stealthwolf
stealthwolf's Avatar
Underbody lance
I bought an underbody lance from autobrite back in 2011. It worked great with my Nilfisk C120. I've since bought an E140.3 and need to change the connector. I've tried both clockwise and anticlockwise but can't seem to remove the brass connector.
Any ideas on how to remove it?
Old 30-05-2018, 11:46 PM   #2
Can you post a pic? If it's metal to metal (ie mild steel and brass) it could be seized in with galvanic corrosion?
Old 31-05-2018, 09:51 AM   #3
stealthwolf
I can post a proper pic when I get home. It's this one:
https://www.autobritedirect.co.uk/in...ess-steel.html
Old 31-05-2018, 12:45 PM   #4
Grin
Probably attached with permanent threadlock. I have heard that heat can loosen the connection. Someone on here successfully tried their gas burner on the hob, although I don't endorse that method.
Grin is offline   Reply With Quote
The Following User Says Thank You to Grin For This Useful Post:
stealthwolf (31-05-2018)
Old 31-05-2018, 04:34 PM   #5
Top Banana
Top Banana's Avatar
see if someone you know has a tap and die kit, saw it of and re thread.
Top Banana is offline   Reply With Quote
The Following User Says Thank You to Top Banana For This Useful Post:
Old 31-05-2018, 11:00 PM   #6
Harry_p
It will most likely just be screwed on, and if it is it will 99.9% likely be a standard thread and will need turning anti-clockwise off the end of the rod.
Chances are some sort of threadlock or sealant has been used.
A little blast with a blow torch and and couple of pairs of grips should see it come off easily enough.
Harry_p is offline   Reply With Quote
The Following User Says Thank You to Harry_p For This Useful Post:
stealthwolf (01-06-2018)
Old 31-05-2018, 11:14 PM   #7
fatdazza
It will be screwed on with a standard clockwise thread. i.e anticlockwise to unscrew.
Grip the barrel as tight as you can (if possible in a vice) and then unscrew the end piece with a large pair of grips.
Old 01-06-2018, 06:12 AM   #8
Cookies
Cookies's Avatar
As fatdazza has said above, get a couple of pairs of mole grips, and itíll definitely come off. Itís probably just stuck as I canít see them ever using thread lock on a lance.
A little bit of heat would be a good shout too. Just watch your flippers though. Lol
Cooks
Old 01-06-2018, 08:12 AM   #9
stealthwolf
Thanks all. I think the bit I was unsure of which way the nilfisk adaptor was threaded on. I've tried mole grips and brute strength with no movement. I was going to use the breaker bar on it next and didn't want to mess things up.
