Go Back   Detailing World > Gallery > The International Showroom
The International Showroom The place the International Detailing World Supporters display their work for viewing : This is a subscription section you will need to go to your userCP (top left of the page) and select Paid Subscriptions for more information.
Old 17-08-2011, 05:02 PM   #1
fishbonezken
fishbonezken's Avatar
Headlight Restoration: BMW 520
A very common sight on many older cars in Malaysia is the yellowing of headlights. We have an equatorial climate here and the heat is at its maximum all year round, this prolonged exposure to heat and UV rays from the sun accelerates the oxidation of plastic headlights. Causing them to yellow, fade, and when looked closely, the plastic is actually cracking.
On the headlights of this BMW 520, it appeared that one of the headlights has been sanded, I guess the technician didn't know how to follow up properly to restore them. So the sanding marks were left behind, and actually looked worse than parts that were not sanded.
When looked up close, the plastic has what I like to call 'Micro-Cracks', from afar they appear to be a yellow film, up close, the plastic is cracking on the surface. When left for too long, the cracks will spread and eventually become deeper, leaving a permanent line on the plastic that even sanding, cannot fully remove.
Most of the time, polishing with a wool/foam pad with a rotating polisher(drill/rotary buffer), can make most lenses clear. Unfortunately, that was not to be in this case.
As seen from the photos above, polishing definitely cleared up the lens, but the results are still not optimal as the micro-cracks are still there and the wool pad is not skimming the surface of the plastic deep enough. Hence, it has to be sanded down.
I expected this job to be done in 3 hours but it took me 6 hours in total. I don't have any process shots as I was pressed for time and the owner is waiting for me to get it done. I also had to redo some portions as I noticed there was still some micro-cracks after final polishing with the foam pad.
Process as below:
(1) Two to three layers of tape around the headlights. This is because the out-most layer will start to lose its adhesiveness and peel when soapy water touches it during the wet-sanding process.
(2) Hand sanded with 400 grit > 600 grit > 800 grit > 1000 grit > 1200 grit > 1500 grit > 2000 grit.
(3) Machine polished with 4" Surbuf Pad and Meguiar's #105 Ultra Cut Compound via rotary @ 1200-1500 RPM
(4) Machine polished with 4" Lake Country CCS Orange pad and Meguiar's #105 Ultra Cut Compound via rotary @ 1200-1500 RPM
(5) Machine polished with 4" Lake Country CCS White pad and Meguiar's #205 Ultra Finishing Polish via rotary @ 1200-1500 RPM
(6) Wiped down with Isopropyl Alcohol (diluted 1:1)
(7) Surface dried with hairdryer to remove moisture.
(8) GTechniq C1 Crystal Lacquer is used to coat the surface to prevent re-yellowing.
(9) Dried again with hairdryer to accelerate curing.
Results on the edges is still a little compromised but way better compared to before.
On the larger areas, looks perfect from far and even 10 cm away. When looked closely, some gouges in the plastic is still there. I think a more uniform finish can be achieved with machine sanding compared to hand sanding.
Finally, some before and afters.
Without flash:
With flash:
After shots:
Thanks for looking at my humble work.
fishbonezken is offline   Reply With Quote
The Following 74 Users Say Thank You to fishbonezken For This Useful Post:
AaronGTi (25-06-2013), aristent (18-08-2011), azeem1 (10-12-2012), Bartl (02-09-2013), BDJ (25-06-2013), Bmpaul (06-12-2016), c87reed (27-07-2016), Cadillacman (28-08-2011), centenary (17-08-2011), Criptop (02-07-2015), crosscyl (28-09-2015), Damien89 (26-08-2011), DetailMyCar (18-08-2011), dhiren_motilal (07-10-2012), elsad-140 (23-09-2012), Estoril-5 (03-09-2012), Eurogloss (18-08-2011), f4rrs (25-11-2013), FabrizioTDI (22-07-2013), GavinC (25-08-2014), GrantB5 (06-07-2015), Gussy (02-11-2013), Hardsworth (25-06-2013), Herefordquattro (18-08-2011), iowa (26-11-2013), j3ggo (03-10-2012), James@ (04-11-2013), jamie crookston (18-12-2013), Jasonlew (20-09-2012), jay p (16-10-2013), jay_bmw (17-08-2011), Jesse74 (17-08-2011), jimmas (26-12-2013), Joech92 (27-08-2014), josadler (22-08-2014), kevepsi (26-08-2011), Kickasskev (02-10-2016), M3simon (25-06-2013), Mad Ad (19-08-2011), mad3lin (29-12-2013), Malborex (30-11-2013), markito (03-09-2012), Matty77 (04-11-2013), neilb62 (12-03-2014), Niall (28-08-2011), onks (07-09-2014), organisys (03-07-2013), orienteer (06-04-2017), Patr1ck (09-07-2013), Pedro92 (11-09-2014), PooPer (26-06-2013), Rabidracoon28 (28-08-2014), reks (20-08-2016), ROMEYR32 (18-08-2011), Rowan83 (20-09-2012), RS 500 (27-06-2013), samharries007 (19-10-2013), samm (18-08-2011), scaniadaft (25-06-2013), sean20 (19-08-2011), siscobmw (03-09-2012), slim_boy_fat (17-08-2011), Socal Brian (25-12-2013), Spaceman1 (25-08-2014), Stewartfinley (25-11-2013), stonejedi (29-07-2013), streaky (30-12-2011), TTCD (05-11-2013), Turbo Tony (03-09-2012), uzi-blue (17-08-2011), VenomUK (18-09-2012), westie (01-09-2014), williamsclio1 (18-09-2016), Xivo (07-09-2012)
Old 17-08-2011, 05:05 PM   #2
DampDog
DampDog's Avatar
Astonished by that, superb work....
DampDog is offline   Reply With Quote
The Following User Says Thank You to DampDog For This Useful Post:
fishbonezken (17-08-2011)
Old 17-08-2011, 05:11 PM   #3
Matt_Nic
Oh my word, thats fantastic!
Are they plastic on the 5? My E46's could do with a tidy up and are plastic - is it safe to use a DA and Menz polish, they're no where near as bad as yours were.
Matt_Nic is offline   Reply With Quote
The Following User Says Thank You to Matt_Nic For This Useful Post:
Archer189 (25-06-2013)
Old 17-08-2011, 05:24 PM   #4
fishbonezken
Hi Matt,
Yep these are plastic lenses, I think most lenses are nowadays. I'm not too sure about the surface material of the E46, I do know that the E36 models still used glass.
DA and Menz polish is safe, just be cautious and not let the sides of the backing plate hit the paint as your are polishing. You can tape them up just to be safe.
Old 17-08-2011, 09:53 PM   #5
BRUNBERG
BRUNBERG's Avatar
E46 ones are plastic but you can buy replacement lenses from GSF for 20 quid each so prob not worth the effort as they take less than 5 mins to change
BTW OP excellent transformation
BRUNBERG is offline   Reply With Quote
The Following User Says Thank You to BRUNBERG For This Useful Post:
fishbonezken (18-08-2011)
Old 17-08-2011, 10:13 PM   #6
cheffi
cheffi's Avatar
Send a message via ICQ to cheffi Send a message via MSN to cheffi
now that was one interesting post, thank you very much!
cheffi is offline   Reply With Quote
The Following User Says Thank You to cheffi For This Useful Post:
Old 17-08-2011, 10:14 PM   #7
Jesse74
Holy crap, nice work mate!!
Jesse74 is offline   Reply With Quote
The Following User Says Thank You to Jesse74 For This Useful Post:
Old 17-08-2011, 10:18 PM   #8
prokopas
prokopas's Avatar
Fantastic turnaround
prokopas is offline   Reply With Quote
The Following User Says Thank You to prokopas For This Useful Post:
Old 17-08-2011, 10:20 PM   #9
uzi-blue
uzi-blue's Avatar
Amazing work, great write up too.
uzi-blue is offline   Reply With Quote
The Following User Says Thank You to uzi-blue For This Useful Post:
Old 17-08-2011, 10:35 PM   #10
OrangePeel
OrangePeel's Avatar
Amazing turnaround... Great work dude!
OrangePeel is offline   Reply With Quote
The Following User Says Thank You to OrangePeel For This Useful Post:
