Go Back   Detailing World > Gallery > The International Showroom
The International Showroom The place the International Detailing World Supporters display their work for viewing : This is a subscription section you will need to go to your userCP (top left of the page) and select Paid Subscriptions for more information.
Old 10-01-2012, 09:52 PM   #1
fishbonezken
fishbonezken's Avatar
Red face Old cars need loving too! Full Detail: Perodua Kelisa/Daihatsu Cuore
Yes it is...it is a Perodua Kelisa, the same model that Clarkson ridiculed in this video:
The car upon arrival.
Some of the products to be used.
So let's start off by getting the wheel, tires and wheel wells cleaned. Wheels cleaned with ValetPRO Bilberry Wheel Cleaner (diluted 3:1), tires and wheel wells cleaned with Osren Degreaser FX (diluted 2:1). Brushes used are ValetPRO Chemical Resistant Soft Brush and ValetPro Long Reach Wheel Brush. Both brushes were a joy to use, especially the long reach brush, stiff enough to scrub and flexible enough to bend.
Panel gaps, rubber and plastic trim brushed with Osren Degreaser FX (diluted 2:1).
Then I noticed all the glass had watermark etchings, so I used Osren's Watermark Remover powder and a 3M Microfine sanding sponge. My technique still needs to be improved on this one as it didn't fully remove all the watermarks, but did significantly reduce it and cleaned the glass, preparing it for coating. Firstly, scrubbed with the sponge and powder, rewashed with shampoo and squeegeed dry.
Car is then washed with ValetPRO Wash and Protect shampoo, followed by Osren Tar Remover on lower panels and wheels, lastly paintwork smoothened with Osren Magic Clay Cloth.
ValetPRO's Wash and Protect shampoo definitely added something on the surface as the glass which wasn't repelling water at all after the cleaning now had a slight water beading effect to it, with just one wash!
With the paint squeaky clean, we now inspect it. Bonnet was in the worst condition, the other panels had the usual swirling, embedded dirt, and water marks. The single stage black painted panels were oxidized and looked grey.
Macro shot of the swirls above.
So I decided to start on the bonnet first. The right side have been repainted and I don't know why it has faded so badly, especially around the area where it 'blends' with the original paint. Let's take a closer look.
Ouch... now let's take an even closer look.
Yikes! That's the area that has been repainted, I assume it is cheap clearcoat and it has 'bubbled' over the years, thus giving it the faded look. The non repainted areas had RIDS, swirls, pitting, watermark etching and embedded dirt, the typical symptoms of neglected paint.
After seeing the bubbling photo, I wanted to give the bonnet a proper cutting. So the process for it was:
(1) Sanding with Mirka Abralon 2000 grit / Speed 2 / Dodo Juice Buff Daddy (Das6 DA)
(2) Sanding with Mirka Abralon 4000 grit / Speed 2 / Dodo Juice Buff Daddy (Das6 DA)
(3) Compound with Osren Velvet Pad and Osren P40 Compound / 1500 rpm / Makita 9227C Rotary
(4) Compound with Meguiar's #105 Ultra Cut Compound and Lake Country 4-ply wool pad / 1500 rpm / Makita 9227C Rotary
(5) Polished with Meguiar's #105 Ultra Cut Compound and Lake Country White Polishing pad / 1500 rpm / Makita 9227C Rotary
(6) Polished with Meguiar's #205 Ultra Finishing Polish and Lake Country Black Finishing pad / 900 rpm / Makita 9227C rotary
The rest of the car received the same steps except for the sanding and velvet pad.
Paint transfer on the driver's side door and rear fender were wet sanded with 2000 grit sandpaper and polished.
So how do you know if it is paint transfer which is above the surface and not a scratch beneath the paint? If you look closely, you can see the 'scratch/scuff' is on the surface, and as you run your fingers across it, you will feel that it is 'sticking out' from the paint, then you know you have a chance to fix the problem.
Water stains around the chrome area were removed with Osren StainX(acid).
Side windows coated with Wolf's Chemicals Glass Guard while the front and rear glass which had wipers were coated with GTechniq G1 ClearVision Smart Glass. Wiper cowl trim dressed with Wolf's Chemicals Trim Coat and wheels with Wolf's Chemicals Rim Shield.
I then moved to the interior, was rushing for time at this stage and didn't take much photos. Process was:
(1) ValetPRO Glass Cleaner on all glass.
(2) Meguiar's All Purpose Cleaner on vinyl seats and all plastic trim.
(3) Vinyl seats conditioned with ValetPRO Argus Leather and Vinyl Cream.
Seats felt a little bit oily after the Argus cream, but after buffing off with a dry cloth and left for a while, it eventually felt non-greasy and smooth. Very nice to sit without too much slip.
With all the little bits and pieces done, final step is to dress the tires with ValetPRO Traditional Tire Dressing and paintwork waxed with ValetPRO Banana Wax, a carnauba liquid wax. Enjoy the after photos! Please excuse the slight haziness on the paintwork as the wax was applied at night right after the rain, the very humid air made it slow for the wax to dry and cure. The humidity was at about ~97% RH!
Thanks for looking! Your feedback is appreciated.
May the good times and treasures of the present become the golden memories of tomorrow. Wish you lots of love, joy and happiness. Happy New Year!!!
fishbonezken is offline   Reply With Quote
The Following 34 Users Say Thank You to fishbonezken For This Useful Post:
AaronGTi (16-08-2012), BareFacedGeek (08-02-2018), euge07 (15-12-2016), Eurogloss (15-01-2012), FabrizioTDI (23-10-2016), georgeandpeppa (20-08-2012), gt5000 (17-08-2012), Joech92 (30-10-2016), JR1982 (02-10-2016), Jue (10-10-2016), markito (14-12-2012), mbrad_26 (04-04-2012), McClane (29-01-2012), Mike07 (21-08-2012), moshinho (13-01-2012), Mr Face (17-08-2012), NornIron (01-10-2016), organisys (28-01-2014), Pedro92 (21-01-2012), point blank (21-07-2017), prokopas (14-01-2012), ShaunButton (13-11-2016), Sk8ir (08-02-2018), skally (19-10-2016), Socal Brian (12-12-2016), stangalang (25-01-2014), steelghost (09-02-2018), Sti_Brumby (13-01-2012), Streeto (08-02-2018), Titanium Htail (16-08-2012), TonyH38 (08-02-2018), Twister (20-08-2012), vigs (28-12-2016), zippo (10-01-2012)
Old 10-01-2012, 10:00 PM   #2
zippo
zippo's Avatar
Outstanding turn around. Ive never seen a detailed pictures of clear coat failure before. Amazing
zippo is offline   Reply With Quote
The Following User Says Thank You to zippo For This Useful Post:
fishbonezken (10-01-2012)
Old 10-01-2012, 10:05 PM   #3
stangalang
king of the flexonian
stangalang's Avatar
Man that is one ugly mutha ****in car, but you did an amazing job in making it it's best. Kudos to you that turned out great
Old 10-01-2012, 10:06 PM   #4
AaronGTi
AaronGTi's Avatar
Brilliant work there.
Well done sir, real credit to you.
AaronGTi is offline   Reply With Quote
The Following User Says Thank You to AaronGTi For This Useful Post:
Old 10-01-2012, 10:08 PM   #5
fishbonezken
LOL!!!
Old 10-01-2012, 10:09 PM   #6
The_Bouncer
DW Sponsor - 'No, you can't come in'
The_Bouncer's Avatar
Location: It isnt all fluffy clouds, flash cars and big cash all the time
Wow
Fantastic work - great close up and correction of paint defects.
The car is brand new again
The_Bouncer is offline   Reply With Quote
The Following User Says Thank You to The_Bouncer For This Useful Post:
Old 10-01-2012, 10:11 PM   #7
The Cueball
The Devil's Advocate
The Cueball's Avatar
car looks great now... well done...
were the clear coat pics taken by microscope?!?!?!?
The Cueball is offline   Reply With Quote
The Following User Says Thank You to The Cueball For This Useful Post:
Old 10-01-2012, 10:13 PM   #8
stangalang
stangalang's Avatar
Fishbonezken, the osren pads you used. These are the ones that can level orange peel to an extent are they? Do you find they need following with wool or is that just a personal preference? And do they work best with Osrens own polish
Thanks, matt
Old 10-01-2012, 10:16 PM   #9
fishbonezken
Thanks!
Not a microscope, just used this:
http://www.foto-tip.pl/sklep/product...84&language=en
A extension tube that fits between the lens and the camera body to achieve a much shorter focusing distance.
The Following User Says Thank You to fishbonezken For This Useful Post:
The Cueball (10-01-2012)
Old 10-01-2012, 10:21 PM   #10
fishbonezken
Thanks, matt
Hi Matt, yup, those are the pads that can level orange peel. I have not experimented using it with other compounds but have heard of another pro here in Malaysia that uses the pad with Meguiar's #85 to level orange peel.
I just follow up with wool as I did not want to guess if a cutting foam/polishing foam is sufficient to remove the velvet pad marks. On softer paints, you *could* go to foam directly, but I prefer at least purple foamed wool, just to be safe. Again, it is paint hardness dependent, so you'll have to do a test spot to be more accurate.
The Following 2 Users Say Thank You to fishbonezken For This Useful Post:
stangalang (10-01-2012), wee man (12-12-2016)
