Old 26-05-2018, 09:06 PM   #1
toptinker
toptinker's Avatar
car pro
hi all. just need a few tips etc.
done the full decon etc. clay bar etc.
2 passes using lime prime.
then I have tried this car pro essence. I do like this. whats your opinion on it ?
think I am ready for applying the gtechniq exo v 3 sealant. my worry is it will be outside over night. will this be ok and any tips on application etc ? thanks
toptinker is offline   Reply With Quote
Old 26-05-2018, 09:38 PM   #2
fatdazza
Lime prime is an oily polish / glaze.
Not sure that is the best base to then put essence over.
Old 26-05-2018, 10:38 PM   #3
PHB1969
Agree with that, ideally you want to be back to the paint with nothing on top. Something like IPA or Eraser to remove it.....
PHB1969 is offline   Reply With Quote
Old 26-05-2018, 10:40 PM   #4
Fairtony
Isn’t essence a souped up cleanser/filler? Id’ve thought it would have been fine.
Fairtony is offline   Reply With Quote
Old 26-05-2018, 10:48 PM   #5
Blackroc
car pro
Exov3 needs to be applied to bare paint too, no polishes or glazes (certainly not Lime Prime) underneath. Pretty sure it’s not a fan of Essence either, most of GTechnics coatings wont sit on on top very happily
Old 26-05-2018, 11:29 PM   #6
toptinker
toptinker's Avatar
thanks chaps. so what should I do now. should I use a panel wipe to clean all off and start from scratch with the car pro essence ? so lets say I use a panel wipe then just use the essence then panel wipe then exo or poss a wax ?
Old 27-05-2018, 01:56 AM   #7
waqasr
waqasr's Avatar
I have used Exo v3 over essence and it works fine. Just make sure you let the essence cure for the required time.
To op, leave out the lime prime, just go essence and then top with exo, or a finishing polish, panel wipe and then exo.
waqasr is offline   Reply With Quote
Old 04-06-2018, 01:18 PM   #8
toptinker
toptinker's Avatar
there looks like some diff opinions on after putting essence on using exo v3 ? some say use panel wipe others saying no need ? would it be safer just to use panel wipe ? if so do you lose some of that shine/gloss etc ?
Old 04-06-2018, 09:24 PM   #9
-Kev-
Moderator
-Kev-'s Avatar
Id be using a panel wipe or similar (envy car care filler killer for example) before using any coating - have you used a good light source to check the paint condition? This is imperative before coating after using panel wipe and also to check you haven't missed any coating when removing residue. Leaving the car outside is different if you can get a sacrafical product on like gtechniq c2 over the coating so it can fully cure - i drove my car home after it got coated in siramik with a sacrafical layer of siramik mist on top no problem as long as it doesn't rain. The issue is using coatings outside, assuming you are. Personally i wouldn't. Mine was done indoors
