Old 12-01-2017, 11:57 AM   #1
jamie.C.D
Cross contamination?
Hello newbie here, glad to be a member and very enthusiastic about detailing. Been interest for a two years or so but finally bought my first DA , it's a DAS 6 pro! I bought three chemical guys quantum pads green (cutting), blue (polishing) and black (finishing).
I then purchased a poorboys super swirl remover sample pack.
My potentially stupid question is , if I was using ssr 2.5 on my blue pad , could I then use ssr 2 on my blue pad straight after. Similar to this , if I'm finishing with ssr 1 on my black pad , could I then apply my liquid wax with the black pad straight after or would there be some form of contamination from the previous compound.
Any help would be much appreciated
jamie.C.D is offline   Reply With Quote
Old 12-01-2017, 12:20 PM   #2
bigalc
bigalc's Avatar
I personally would use different pads for different products.
However if going from a fine polish to something more aggressive I don't see a problem, but not the other way around.
I would also recommend using a clean pad for a liquid wax.
Old 12-01-2017, 12:22 PM   #3
Mcpx
Ideally you would use a different pad with each compound to avoid precisely that problem, but at least clean them between stages. For applying waxes and glazes I use the pads sold by Halfrauds, only a few £££, you don't need any cutting power for this so just get the softest ones, black or pink if I recall.
http://www.halfords.com/webapp/wcs/s...0151&langId=-1
Old 12-01-2017, 12:22 PM   #4
N16k_W
You would need a fresh pad for every compound. I would recommend buying a few more of each pad. 3 of each should be enough for any one car
N16k_W is offline   Reply With Quote
Old 12-01-2017, 02:06 PM   #5
jamie.C.D
Answered my question perfectly guys , thanks a lot!!
Old 12-01-2017, 11:17 PM   #6
lowejackson
lowejackson's Avatar
Just wash each pad before using a new product. Wash each pad after a panel or two anyway. Dirty or polish soaked pads are not longer effective and can cause the pad to overheat, washing them makes a big difference
Old 12-01-2017, 11:22 PM   #7
Just use a different pad for each polish you use.
Old 13-01-2017, 09:47 AM   #8
Bigpikle
Bigpikle's Avatar
Optimum polishes allow you to mix and match polishes without having to get a fresh pad each time - they make a feature of that. There is a genuine synerg y between products but not sure I'd do it with other brands that promote this capability.
The Following User Says Thank You to Bigpikle For This Useful Post:
chongo (13-01-2017)
Old 13-01-2017, 11:39 PM   #9
lowejackson
And just as nice, you can wash the pads in a bucket of ONR to get them nice and clean, spin dry near the top of the bucket and then apply fresh polish. The Hyper range is perfectly happy with a slightly damp pad as it also helps with the lubrication. If pads are in a bad way just a quick spray with Power Clean and then dunk the pads into ONR
