Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bilt Hamber
Old 19-02-2018, 11:50 AM   #101
Brian1612
Originally Posted by DTB View Post
I wonder why there is a difference between what PH you got and what I got? Tap water here is pretty much bang on neutral and the machine I used is a calibrated unit in our work lab. I'll mix up another solution of 4% later in the week and test that. I'll also test it neat just for interest.
Have read very varied results for it from test to test. My tap water was actually slightly alkaline as well so certainly not neutral. I will retest it also and see what I get. I know neat its PH12.
Sent from my GT-I9505 using Tapatalk
Old 19-02-2018, 03:39 PM   #102
Forsh
Forsh's Avatar
Might be of use here...
https://www.screwfix.com/p/green-pre...yer-7ltr/51100
The Following 2 Users Say Thank You to Forsh For This Useful Post:
Brian1612 (19-02-2018), steelghost (19-02-2018)
Old 19-02-2018, 05:29 PM   #103
Radish293
Radish293's Avatar
Originally Posted by Forsh View Post
Bought one. Great for the money maintains pressure but the plastic clip to hold the lance when not in use is a bit brittle.
Forsh (19-02-2018)
Old 28-03-2018, 03:51 PM   #104
46philh
Who uses this on CSL + EXO ? Was it ok after long term use ?
I asked Bilt Hamber direct but unable to answer.
46philh is offline   Reply With Quote
Old 29-03-2018, 08:48 PM   #105
Negaultra7
Negaultra7's Avatar
Hi can you please tell me the dilution amount I need?
I use a Karcher FJ6 foam jet nozzle and a Karcher K2 Compact pressure washer
Any advise will be appreciated
cheers
Neil
Negaultra7 is offline   Reply With Quote
The Following User Says Thank You to Negaultra7 For This Useful Post:
Brian1612 (29-03-2018)
Old 29-03-2018, 08:53 PM   #106
cheers
Neil
As Brian mentions, every setup needs testing separately. You will need to follow the steps given under the heading "As a snowfoam" in the review
Old 18-04-2018, 06:40 PM   #107
richtea78
I’ve been thinking about the drying problem as the weather warms up. Could you do a few panels at a time rather than soak the whole car at once then risk it drying?
richtea78 is online now   Reply With Quote
Old 18-04-2018, 10:44 PM   #108
Brian1612
No reason why you couldn't richtea. Still want to make sure it gets 1-2 mins dwell time without drying out also.
richtea78 (19-04-2018)
Old 07-05-2018, 12:45 PM   #109
magicone
Annoyingly both snow foam bottles I have even though they say they are 1 litre are slightly under. Can I still measure the impact ratio say if I start off with 900ml in the bottle?
magicone is offline   Reply With Quote
Old 07-05-2018, 02:17 PM   #110
Brian1612
You can. Just work out the ratio accordingly using 900ml instead of 1000ml in the bottle.
magicone (07-05-2018)
bilt hamber auto foam, prewash, snow foam, touchless car wash
