Old 08-03-2018, 08:10 PM   #1
RP84
RP84's Avatar
Kitchen plinth help
Hi,
I need to fit some kitchen plinths and just slightly confused
Using example numbers
So the plinth width is 200mm and the gap from the floor to the cabinate is 150mm
So I know I need to scribe the plinth but then do I then cut the top part of the plinth straight too? If so how do I know that I’m getting the exact size
Can’t figure it out
RP84 is offline   Reply With Quote
Old 08-03-2018, 08:15 PM   #2
If your floor is flat and straight, mark the 150mm (or actual size), cut down to right size and fit.
Make sure you use a sharp saw and ensure you cut right side of the face - so the rough edge is inside the unit (if that makes sense) and cut the top off the plinth, so the cut edge isn't obviously seen - you have the factory straight cut to the floor that's on show...
RP84 (08-03-2018)
Old 08-03-2018, 08:20 PM   #3
RP84
RP84's Avatar
Thanks, floor isnt straight which is annoying
The Following User Says Thank You to RP84 For This Useful Post:
Andyblue (09-03-2018)
Old 08-03-2018, 08:21 PM   #4
wish wash
wish wash's Avatar
Don't cut it too tight for height, if you ever need to remove it in the future it can be a nightmare to get it back out. If the ends ain't sealed then I put pva on them to stop them swelling with water from people mopping the floor
The Following 2 Users Say Thank You to wish wash For This Useful Post:
kh904 (09-03-2018), RP84 (08-03-2018)
Old 08-03-2018, 08:24 PM   #5
dchapman88
dchapman88's Avatar
If you have to scribe, maybe invest in a product called the 'perfect butt'
Quality product for scribing
Also depending on the length of the plinth may be a jigsaw would be a lot easier than handsawing
Top tip above about coating in PVA too to seal the edges
RP84 (08-03-2018)
Old 08-03-2018, 08:41 PM   #6
DrEskimo
DrEskimo's Avatar
You can get a rough estimate of the angle by measuring both sides of the cabinet and noting the difference in height.
Don't worry too much though. As Andy says, since you put the cut edge on top, if you are a couple of MM too short, you wont be able to see it. Even if you put your head right to the floor it's still difficult to tell
The Following User Says Thank You to DrEskimo For This Useful Post:
RP84 (08-03-2018)
Old 08-03-2018, 08:53 PM   #7
Darlofan
Well, I've just googled "perfect butt" 🤤🤤 Lucky the wife is out😂
Darlofan is offline   Reply With Quote
The Following 2 Users Say Thank You to Darlofan For This Useful Post:
johny555ive (07-04-2018), RP84 (08-03-2018)
Old 08-03-2018, 09:00 PM   #8
dchapman88
dchapman88's Avatar
I assume this is what you found......
https://www.amazon.co.uk/Trend-TREPB.../dp/B0029WD590
Haha
Old 08-03-2018, 09:03 PM   #9
Darlofan
Haha
Let's just say that was down the rankings slightly.
The Following User Says Thank You to Darlofan For This Useful Post:
dchapman88 (08-03-2018)
Old 08-03-2018, 11:26 PM   #10
RP84
RP84's Avatar
Cheers guys, I will give it ago tomorrow,
I think first scribing and then cut the top if needed. I guess if there is a little gap I could always use sealant
good shout on the pva
