Old 07-08-2017, 08:35 PM   #91
Originally Posted by JamesRS5 View Post
Have any of you guys with pad rotation problems tried the spacer washer modification to move the backing plate away from the dust cover?
Also, do you have enough lubrication on the backing plate? Rupes say the backing plate must be lubricated where touches the dust cover.
I have the washer mod and it certainly makes a difference
Old 08-08-2017, 10:57 PM   #92
Triggauk
Had the same issue..... brought the kamikaze beast plate... and now I don't!!
Triggauk is offline   Reply With Quote
Old 10-10-2017, 02:56 PM   #93
euge07
euge07's Avatar
I fear my polisher has these symptoms now as well
might just go for a flex and save any hassle
Old 10-10-2017, 03:19 PM   #94
Which flex bud.
Old 10-10-2017, 03:31 PM   #95
suspal
suspal's Avatar
The 3401 is the machine to go for the Xfe7 is a finishing machine,yet to use the xfe in anger yet.
suspal is offline   Reply With Quote
Old 10-10-2017, 03:50 PM   #96
euge07
euge07's Avatar
Originally Posted by chongo View Post
Which flex bud.
going to see about getting my rupes sorted, it seems to be ok on very flat surfaces, but when gets near any curved or odd panels it seems like it hasnt enought bite and doesnt perform well, it doesnt do it all the time though,
I see the post above about lubricating in around the backing plate, I'll be honest, I've never done this or knew you had to?
It would be a 3401 vrg I would go for or if the new da had enough bite in it I would get it
Old 10-10-2017, 07:41 PM   #97
JamesRS5
JamesRS5's Avatar
Try using an M8 washer to space out the backing pad from the machine, you won’t have any issues after this.
JamesRS5 is offline   Reply With Quote
Old 10-10-2017, 07:56 PM   #98
Robbi Hong Kong
Robbi Hong Kong's Avatar
Got a Kamikazi Beast Backing plate on my 15 Mk2....really changes the machine for the better but its a very very expensive upgrade!
Robbi Hong Kong is offline   Reply With Quote
Old 10-10-2017, 09:26 PM   #99
suspal
suspal's Avatar
This is where I believe Rupes have gone wrong,it takes Kai in Japan and Mr Brown in the USA to come up with aftermarket solutions,and the same goes to flex with the 3401 where Lake country have prodused an aftermarket backing pkate system,for the life of me I don't and can't see why companies do this,as the machines themselves arn't cheap.
So I suggest that both Flex and Rupes have a rethink on how they can put wrongs to right,they'd probably sell more machines if they put the customer a little more in their thought process.
No offence to Kai or Kevin in fact they should be thanked.
There should be no reason to exploit loyal customers or is it make loyal customers purchase smaller machines that increases revenue?
Could these companies not have foreseen these problems !!!!
The Following User Says Thank You to suspal For This Useful Post:
euge07 (10-10-2017)
Old 10-10-2017, 09:33 PM   #100
LeeH
LeeH's Avatar
Did the OP ever get his machine back?
LeeH is online now   Reply With Quote
buy a flex, faulty, rupes, rupes bigfoot, stressful, summit detailing
