Old 05-08-2017, 11:25 PM   #1
TrixterDK
Not getting cut
So I've. Read and read and still learning.
I have done two black Audi a6 black both and iam not 100% happy with the results. Is seams that I always have to go for the hardest pad and most cut compound.
I have scholl s03 and s17 and s40. Also m105.
I have all the scholl spider pads and cc hex pads and lc ccs pads.
Flex 3401 machine.
Both audis I got the best from white spider and s3.
I see a lot of guys using something with less cut. But I don't seam to get this to work. Tried with orange, green and yellow hex pads.
I do around 8 passes and still some scratches. I go very slowly and tried with and. Pressure.
I would just like to go a little less aggressive but don't seam to be able.
Just did one to day 8 hours and not 100% happy.
Sould i try something else compound or pads?
I know it's hard to answer but please try
TrixterDK is offline   Reply With Quote
Old 06-08-2017, 01:57 AM   #2
Alfieharley1
I apologies before if this is a half asleep post.
Ok to summarise - Audi have hard paint which means you are always going to need a harder set to correct then for example a Japanese.
For German paint I always use a microfibre cutting and finishing pad.
(regulars do a really nice microfiber set of Polish/compound & also pads)
Hopefully someone like Stangalang or Chongo will be along in the morning who will be able to expand.
Alfieharley1 is offline   Reply With Quote
Old 06-08-2017, 05:25 AM   #3
TrixterDK
What pads do you use??
Old 06-08-2017, 05:27 AM   #4
Alfieharley1
http://www.in2detailing.co.uk/produc...tting-pad.html
http://www.in2detailing.co.uk/produc...shing-pad.html
Old 06-08-2017, 06:35 AM   #5
stangalang
king of the flexonian
stangalang's Avatar
Ok, some things of note from what I read.
You are comparing yourself to what you think others achieve. As in, "they" get these results so why cant i. Well "they" may not be telling the whole truth in their posts, setting you an unrealistic goal. "They" may simply be better at it than you and you just need more practice. There is absolutely no reason you should be able to do anything swell, straight away, just because you want to. Plus they may have better time constraints to you
You say "I do around 8 passes and still some scratches". Swirls are easy to get out, scratches not so. You may have to hit heavily scratched panels multiple times to get the desired results, which takes time. And individual RDS take time and precision to remove. Again, not something I would expect people to be able to do after a couple of cars
You also say "Just did one to day 8 hours and not 100% happy". There is no way you get a car 100% in a day. If someone says or suggests they did, then they are lying or have low standards as to what 100% is.
I think your biggest issue is one of perception. You have set yourself unrealistic goals based on your perception of what others achieve. You will without question improve as you do more cars for friends and family. But you should be really taking your time and learning to enjoy the process, and enjoying to learn. All the little things you pick up each time add up to an improvement on the next car, and so on. Setting time constraints when they are not required only breads poor results and leaves no time to learn
So to the actual mechanics of it. If you are using a forced rotation da then you have torque. Add in a wool pad to your tools. Its not about how much it cuts, but HOW it cuts. Wool kind of rips into paint meaning scratches are rounded out more easily. MF and foam will never remove such marks like wool will unless you are edging. Wool and m105 is a beast of a combo
Old 06-08-2017, 07:12 AM   #6
dchapman88
dchapman88's Avatar
Ok so I'm no pro but will chuck in my two pennies
My best advice would be to use any 'disappointment' as a learning tool to just move on and adapt ready for your next car.
For example I've done cars that should have been 'easy' to polish as in theory they should of had softer paint but they didn't and I really struggled. I was in no way happy with my results, but I then went and got a scrap panel for practise. Practise on this made me realise i needed some kit changes so bought some MF pads to try which gave me better results on my scrap so the next car I did was a Merc so I went straight for the MF pad to cut and it gave me a better result.
If you can learn to enjoy it and not let what you believe to be poor results bog you down then you'll get to grips with it easier.
All IMO obviously
Sent by a phone of some description!
Old 06-08-2017, 08:11 AM   #7
Basically what matt as said, so your not getting the desired results you hoped for so of course you not going to be happy I was the same when I first started off but I know by experience that practice and a little bit of patience will soon get you the results you are looking for I tend to give advice on what products work for me not how to work them, as that's where you need find out and the only way is practice.
To this day I still am learning when it comes to machine polishing as every car is different but my approach still remains the same You will get there just take your time and hopefully you will start to see the results
Old 06-08-2017, 08:58 PM   #8
TrixterDK
Thank you so much. I really appreciate it.
Maby I am setting the bar to high. Iam learning each time and live it.
I know there is no way to lean this skill fast.
Again I really appreciate it
The Following User Says Thank You to TrixterDK For This Useful Post:
stangalang (06-08-2017)
Old 06-08-2017, 09:40 PM   #9
stangalang
stangalang's Avatar
Everything takes time to learn. The one you do it the more you will achieve. But do remember, there is a lot of smoke and mirrors on here, and its not there fault. They have an idea of what is achievable and want to present a good thread, so don't tell the whole truth to look as good as the next guy.
just do you
TrixterDK (07-08-2017)
