Go Back   Detailing World > Gallery > Garage/Product Collections
Garage/Product Collections Post your Garage or Product Collection pics here....
Old 24-03-2016, 09:19 AM   #1
klw7me
klw7me's Avatar
Garage Floor Paint £14.99
Hi all, spotted that this goes on an Aldi specialbuy for £14.99 for 2.5l on Thursday 31st March. Thought it was a good deal and I will be checking it out as mine needs doing.
https://www.aldi.co.uk/light-grey-ga...69844028311301
klw7me is offline   Reply With Quote
Old 24-03-2016, 09:39 AM   #2
lick0the0fish
How do you make sure it sticks to the floor? I want to do mine but don't want it to peel
lick0the0fish is offline   Reply With Quote
Old 24-03-2016, 09:14 PM   #3
klw7me
klw7me's Avatar
seal it first or dilute it with a bit of water, some people use pva glue first
Old 25-03-2016, 08:12 AM   #4
Tom_the_great
Tom_the_great's Avatar
That is the worst idea, sorry to correct you.
Paint works by soaking in and creating a mechanical bond. To ensure the paint sticks the floor should be clean dry free from contamination and most important porous !!! You do not want the paint to simply sit on the surface as it will peel, so please do not use pva or any sealant when painting
I am happy to help if anyone has more questions, I work for the worlds largest paint company in technical.
Tom
Tom_the_great is offline   Reply With Quote
The Following User Says Thank You to Tom_the_great For This Useful Post:
organisys (08-04-2016)
Old 25-03-2016, 08:38 AM   #5
Mr K
Mr K's Avatar
In my experience unless it is painted then not used and not walked on which isnt going to happen it will lift in time.
I had plastic ' chequer plate design ' tiles put down on my garage floor and very pleased with the result
I bought them from www.softfloor.co.uk and for a double garage 6.5m x 4.6m cost £325
Mr K is offline   Reply With Quote
Old 25-03-2016, 08:59 AM   #6
lick0the0fish
I guess the only issue with tiles is they need to be strong enough to support axle stands and trolley jacks. I've heard stories of plastic tiles that can be crushed under the weight of the car.
How would you go about ensuring the floor is clean/dry enough to paint?
It's a new build garage has been there for 6 months standard concrete "self levelling" (according to the builders) floor
Old 25-03-2016, 09:18 AM   #7
klw7me
klw7me's Avatar
Tom
Thanks for the correction I was just going on what I know other people have done. I am looking to seal mine first, is it best diluting the first coat with water a little or is there another way?
Old 25-03-2016, 10:13 AM   #8
tigerspill
My experience is that most floor paint doesn't work in a garage. There is condensation sits on top and unless there is a perfectly sealed membrane in the concrete, damp will rise lifting the paint from below.
Two pack paint can be better.
The other problem is that once it starts to lift or wear, it looks worse than no paint.
After 20 years of trying, I am going for tiles. There are plenty that can be used for garages that will be OK for jacks etc. Even clearer ones are fine if you get a plate to use.
Another option is just to seal it and not paint. This stops the dust at least. But diluted PVA isn't really up to the job. Get something more specialist.
tigerspill is offline   Reply With Quote
The Following User Says Thank You to tigerspill For This Useful Post:
Tom_the_great (25-03-2016)
Old 25-03-2016, 10:47 AM   #9
Mcpx
Doing mine soon so would be interested in peoples experiences and recommendations.
Saw the Aldi paint but Leyland Trade floor paint is only 2 quid more at Screwfix and is well rated, and it was the deal of the day yesterday at £12 which I found at 11 o'clock last night and bought the last tin at my local, so I am going with that.
From reading around it seems the most successful method is to put down a diluted coat of emulsion first, much like you would do with fresh plaster, to act as a primer without killing off the porosity altogether, and I have plenty of bits of emulsion that I can mix up to do the job.
I am going to have to do mine in two sections due to having nowhere else to store everything, so it will probably be about an 80/20 split, and doing the 20% part first will allow me to see how well it works, whether a second coat is required and most importantly what the drying time is likely to be.
Old 25-03-2016, 10:50 PM   #10
Tom_the_great
In all fairness paint can be more then suitable however you have to see the limitations of single pack paint vs 2 pack etc etc...
Unfortunately the most important part is the floor does it have a Dpm does it get damp how old is it etc etc
Also what is use of the floor and most importantly cost vs use...
In most cases the plastic jigsaw type floor mats work best. Paint wise unless it's a big high end garage paint it and expect it to lift in some places then re coat.
As for best practice when applying a first coat of the material is water based then yes dilute anything up to 20% clean water and mix well
and remember many thin coats are much better then one or two thick coats.
Hope this info is helpful
Tom
The Following 3 Users Say Thank You to Tom_the_great For This Useful Post:
Citromark (26-03-2016), mirdif64 (27-03-2016), nickyd (29-03-2016)
