Old 07-09-2017, 10:37 AM   #1
Leel
Fallout remover
Hi
I'm looking for a cheaper alternative for iron fallout. Currently I'm using iron x, which is very good but not the cheapest product. Recently seen valeting products devils bleed on offer but don't know if it's any good ?
Has anyone used devils blood ? Or can recommend an alternative?
Leel is offline   Reply With Quote
Old 07-09-2017, 10:39 AM   #2
bradleymarky
bradleymarky's Avatar
Bilt hamber Korrosol is around £13 for 1 Litre from Polished Bliss with free delivery.
bradleymarky is offline   Reply With Quote
Old 07-09-2017, 11:30 AM   #3
Rayaan
Rayaan's Avatar
Originally Posted by Leel View Post
Hi
I can recommend Triple QX Fallout Remover after testing alongside KKD Ferrum.
The Triple QX can be bought from Euro Car Parts and is very cheap. It doesn't bleed as well as the others, but after spraying with KKD Ferrum, there was no more fallout. This was tested on my white RX which hadn't touched fallout remover in 1 year.
So you pays your money and makes your choice. Do you want fallout removal or bleeding? Ultimately, products with more of the active bleeding agent are going to cost more, simply because its a more expensive agent to begin with.
Old 07-09-2017, 12:04 PM   #4
Brian1612
Depends whether your buying in bulk or not also. If it's only a small bottle Korrosol every day of the week.
Rayaan was this performed on a wheel with particularly bad fallout build up or something with very little embedded particles in the first place?
The real test would be on wheels that are heavily contaminated. If they aren't that bad you likely won't see a massive difference in performance.
Old 07-09-2017, 12:04 PM   #5
euge07
euge07's Avatar
http://www.in2detailing.co.uk/produc...mover-gel.html
this is the best value for money one ive used, i love it
Old 07-09-2017, 01:20 PM   #6
Rayaan
Rayaan's Avatar
It was on my bonnet. I wanted to see whether the Triple QX was any good and at £6 for 2.5l thought I would try it. Classic test - i.e. taped up and half bonnet covered and KKD sprayed on other half. Bled fairly well and easy to see on my car because its white. Sprayed Triple QX on other side after rinsing and covering up KKD side. Rinsed and then KKD over the whole bonnet.
Both sides reacted exactly the same.
I believe other members have done it on their wheels against Iron X and found no extra bleeding after applying Iron X over TripleQX either. The triple QX just doesn't bleed as well but it certainly works.
Brian1612 (07-09-2017)
Old 07-09-2017, 02:13 PM   #7
euge07
euge07's Avatar
got a discount code handy for ECP ?
Old 07-09-2017, 02:18 PM   #8
E60525d
TripleQX
Old 07-09-2017, 02:27 PM   #9
Brian1612
On that note I am going to grab 2.5l of it and try it out against Korrosol. Almost sounds to good to be true at that price!
Old 07-09-2017, 02:34 PM   #10
Brian1612
SAV8574
34% off with this code. Works out £6.92 for 2.5L of the stuff.
MDC250 (07-09-2017)
