Old 08-08-2018, 09:24 PM   #1
vw754
vw754's Avatar
do i need a different pad? or cutting polish?
I have the das-6 pro D.A, ihave done a few carsfriends/family,and i have done my black audi a5 using meguiars m105 i get brilliant results BUT i can see very faint hair-line scratches when looking at the paint from approx 12 inches i can still see faint scratches on the body i am talking very faint but i would like it to be 100% gone,they are defenatley not deep at all,can hardly see them unless in the sun or i sit about 12 inches away,i have been using this pad ......................https://www.autobritedirect.co.uk/in...te-direct.html
and megs 105.............any better pads ?
i cant seem to get the faint lines out,its very faint,like its gone past a bush at some time and its just caught it
vw754 is offline   Reply With Quote
The Following User Says Thank You to vw754 For This Useful Post:
Tashfeen (08-08-2018)
Old 08-08-2018, 09:49 PM   #2
stangalang
king of the flexonian
stangalang's Avatar
What refining pads and polishes did you use on these other cars you did, and which did you use on this particular car?
Old 09-08-2018, 12:11 PM   #3
vw754
vw754's Avatar
I Used the above cutting pad with 105,then i used a hex logic finishing pad,using meguiars ultimate polish,then waxed.
car looks stunning but close up the faint lines are still visible.
Old 10-08-2018, 01:03 AM   #4
Sheep
M105 is quite aggressive, maybe need to follow up with something a little stronger than UP. In my limited experience with UP so far, it's got far less cut than M205. Maybe try that instead?
Old 10-08-2018, 07:18 AM   #5
AnthonyUK
Does meguiars ultimate polish have a filler like SRP does? This could help mask very feint lines.
AnthonyUK is offline   Reply With Quote
Old 10-08-2018, 09:19 AM   #6
JimBobJones
New to this stuff, but facing same issues as OP.
Just finished pass with M105 on my car, still seeing faint scratches like above. Trying to get my head around the logic of a lesser pad / polish(M205) being able to remove this if the M105 with cutting pad couldn't do it.
JimBobJones is offline   Reply With Quote
Old 10-08-2018, 09:37 AM   #7
percymon
Can't comment on M105, but i've used Menzerna 2200/4000 combo on Audi and Porsche paint with very good effect. Latterly ive found that Menzerna fast cut breaks down so well that it's been a good replacement to 2200 when a degree of correction was needed
Old 10-08-2018, 09:44 AM   #8
ENEP
ENEP's Avatar
Hard to say, but could be compound inflicted swirls and/or DA haze. Less aggressive pad and polish combo should fix it in that case.
Old 10-08-2018, 01:30 PM   #9
riskypicker
riskypicker's Avatar
Ive used 105 on similar BMW paint with a DAS6 pro and CQ Orange Hexlogic. Found it needs additional lubricant (Chemical guys do one or just deionised water) or it dusts and drys before youve achieved the correction youre looking for and also left its own marks.
So i found it needed to be followed by 205 to finish it off - again needs lubricant.
I think the hard paint and the ageing recipes for 105/205 means you may need a longer working time that you may be trying at the moment.
Old 10-08-2018, 02:00 PM   #10
Frog
From reading your post, the scratches you are talking about are still visible in the surface and they are scratches caused by damage prior to cutting/polishing?
If you are happy with the finish (apart from the still visible scratches) that your existing combination has produced may be you just need to have another go at those specific areas again?
