Old 13-07-2018, 09:51 AM   #1
Jaguarsimon
Really stubborn watermarks on windows
Hi there,
Has anyone got any experience of removing watermarks on windows. After years of using a jetwash and not drying the windows I have water mark spots all over my windows which I can't get off. Presumably it's limescale and the deposits around each drop that have dried have dried so hard over such a long time.
I presume abrasion or chemical or combination will remove them, but I don't want to damage rubber around windows or paintwork if using chemical say cillit bang limescale remover or scratch the glass if too abrasive.
I've tried autoglym glass polish, neat vinegar with a non scratch kitchen cleaning pad both of which have had no effect at all.
Can anyone help as it's driving me mad as I've spent so long cleaning, polishing and waxing the body which looks great but the windows look terrible.
Many thanks,
Simon
Jaguarsimon is offline   Reply With Quote
Old 13-07-2018, 09:56 AM   #2
Bar keepers friend
I had an issue with a failed sealant in windscreen that dealer applied and I tried everything I had / could think off, included jif - which normally works, but nothing was shifting it.
Bought some of this - powder version - and worked a treat. Now use it if windscreen has anything on it and it cleans it wonderfully.
Also heard / read about people using 0000 grade steel wool to shift stubborn marks...
Old 13-07-2018, 10:16 AM   #3
MBRuss
MBRuss's Avatar
If you still have the vinegar, soak a piece of kitchen roll in it and also it on the window. Letting the vinegar soak and dissolve the limescale works nicely and involves no scrubbing.
Old 13-07-2018, 01:19 PM   #4
GSD
I really wouldn't use steel wool.
GSD is offline   Reply With Quote
Old 13-07-2018, 03:27 PM   #5
Mrmojorisin007
In really stuburn cases I've used bathroom calcium cleaner - Viakal works a treat.
Mrmojorisin007 is offline   Reply With Quote
Old 13-07-2018, 03:35 PM   #6
spyk3d
I've had this an used 0000 grade wire wool. Make sure it is 0000 grade wire wool and nothing else as any other grades will put scratches into your glass. You could also try claying the area to see if that will break down some of the staining.
spyk3d is offline   Reply With Quote
The Following User Says Thank You to spyk3d For This Useful Post:
westerman (15-07-2018)
Old 13-07-2018, 05:12 PM   #7
Jaguarsimon
Thanks for the replies. I'm not sure where I can get bar keepers friend powder apart from on-line. However, I have just received some 0000 wire wool to try. It is amazingly soft so I don't think it will scratch the glass but will try on a small area first. I think I might use some vinegar as a lubricant with it, and of course will clean the windows first to ensure there is no grit or anything on them which will of course scratch the glass. A clay bar had absolutely no effect at all.
Old 13-07-2018, 05:15 PM   #8
garage_dweller
I'm no
Shops like Home Bargains usually sell it. I've used that mixed into a paste and it did a great job on the windscreen. Also used 0000 wire wool and it's perfecly safe.
Old 13-07-2018, 05:50 PM   #9
Jaguarsimon
I'll check out home bargains for it. Just watched a few youtube videos of people using 0000 wire wool on their car windows, even tinted ones. But they use it dry so I might try that first.
Old 13-07-2018, 06:21 PM   #10
"The Range" sell it, if you've one near...
