Old 07-11-2018, 09:28 PM   #1
tomstephens89
Kranzle hose set ups?
Hi all, I am the proud new owner of a Kranzle K10 and have a question about the pressure hose.
I have purchased quick connect fittings for the gun and Lance's so I am able to easily change between Lance's and snow Foam attachment etc... However I didn't get anything for the hose and of course it's the standard screw fitting on each end.
When packing the machine away, it's easiest to remove the hose and coil it up around my arm then hang it on a hook. Question here is if constant unscrewing/rescrewing of the hose to both the machine and the gun is going to damage the threads over time?
Do any of you guys have some type of quick connect fittings between the machine and gun to allow quick/screwing free removal of the hose?
Or is there nothing to worry about?
Tom
tomstephens89 is offline   Reply With Quote
Old 07-11-2018, 09:42 PM   #2
WristyManchego
Yeah mate, if you’re doing the dirty screw work, look into the quick fittings available for pressure washers. Typically come as a male you attach to the trigger/accessory and a female to attach to the hose.
Exactly the same as an air gun.
The other answer to your question is no, there’s no damage to your threads unless you are a bit solid and like to cross thread. Typically the threads on good quality washers are above the old cross threaddable ratio (made up) where the density is such that you can’t.
Quick connectors are purely to save time.
WristyManchego is offline   Reply With Quote
Old 07-11-2018, 09:59 PM   #3
tomstephens89
Ok so I'm not going to damage these big ass threads so long as I'm not an idiot and crossthread. What quick connect fittings would I need for the hose to machine and hose to gun then as I believe these are different than the ones I have from gun to Lance's.
I do have another plan.... If I was to get a 20m pressure hose on a reel, this washer could live where it sits in the garage and I'd have no need to move it outside. I could leave the hose reel connected to the machine all the time and just have a quick connect between hose and gun.
Suggestions?
Tom
Old 07-11-2018, 10:05 PM   #4
bigbruiser
bigbruiser's Avatar
I just did the same on my K10 i went for M22 to 3/8 couplings
I have used equip2clean & pressurewasherpartsuk on ebay all 1st class
Stay well away from Q washers IMO really terrible service, faulty parts nightmare to get hold of and attitude save your self the headache
Old 07-11-2018, 10:05 PM   #5
WristyManchego
Yeah mate, great idea with the permanent reel, much easier than lugging. 20m of quality of hose ain’t cheap though.
Call your Kranzle rep mate, I’m sure they’d be happy to send recommendations and give you what you need.
Old 07-11-2018, 10:17 PM   #6
tomstephens89
The hose fittings are all the same M22 type as the ones used between Lance's and gun. So I can just get the same TEMA ones that I got here:
https://rover.ebay.com/rover/0/0/0?m...2F113186096404
A female threaded female connector for the unit itself, a male threaded female connector for the business end of the hose. Then a male threaded male connector for the machine end of the hose, and a female threaded male connector for the gun hose bit.
Make sense?
Old 07-11-2018, 10:31 PM   #7
WristyManchego
Make sense?
Why are you telling me? You’re the one that asked mate.
Old 07-11-2018, 10:43 PM   #8
tomstephens89
Answering my own questions again!
Old 07-11-2018, 10:45 PM   #9
WristyManchego
Ha, righto. Glad you found what you were after.
Old 07-11-2018, 10:56 PM   #10
tomstephens89
Looks like about 130 notes for a decent hose on a reel with stand. Plus another 50 for the fittings.
