Wheels, Tyres & Exterior Trim Wheels, Tyres & Exterior Trim Sponsored by ValetPRO - ValetPRO was founded in 2005. We are a UK based company and manufacture our products from ValetPRO HQ in Newhaven, East Sussex. Our vision at ValetPRO is to produce the highest quality car care products and to be the trusted brand of choice for retailers, professional detailers and car care enthusiasts everywhere. We value creativity and are constantly looking for new ways to improve our existing products or develop new ones. We are on hand to provide expert advice on our products and we are always happy to hear about your experience from using any of the ValetPRO range and receiving any feedback that you may have.
Old 29-11-2018, 11:27 AM   #1
camerashy
'Detailing Devil'
camerashy's Avatar
TexTar Cera Tec v Corrosion Block
I have both of these for when I take my wheels off is any one better than the other please.
Am I right in thinking that they are both better than Copper Grease.
Old 29-11-2018, 11:36 AM   #2
toni
toni's Avatar
Send a message via Yahoo to toni
I've found Ceratec very weak at stopping corrosion.
Copper Grease is much better in my opinion.
toni is offline   Reply With Quote
The Following User Says Thank You to toni For This Useful Post:
camerashy (29-11-2018)
Old 29-11-2018, 11:39 AM   #3
Oh I’m old school - use a thin smear of copper grease and no issues - sorry can’t help with your choice bud
Old 29-11-2018, 12:50 PM   #4
\Rian
\Rian's Avatar
Ive stoped using copper grase in favour of
Creamic grease by CeraTec, I use it every time for bolts and remounting wheels on the HUB,
NEVER use copper grease as it causes galvanic corroision
https://www.eurocarparts.com/ecp/p/c...oaAsupEALw_wcB
\Rian is online now   Reply With Quote
Old 29-11-2018, 02:39 PM   #5
camerashy
'Detailing Devil'
camerashy's Avatar
Do you apply it to your wheel bolts as well?
Old 29-11-2018, 06:57 PM   #6
WaxIsForWinners
WaxIsForWinners's Avatar
CeraTec is great on wheel hubs. Used it a lot when swapping from winter to summer wheels and vice versa.
There are many schools of thought on lubing wheel nuts/studs/bolts, but if you give them a good clean and small smear of lube e.g. optimoly / CeraTec then you should be fine.
WaxIsForWinners is offline   Reply With Quote
The Following User Says Thank You to WaxIsForWinners For This Useful Post:
Old 29-11-2018, 07:26 PM   #7
nbray67
nbray67's Avatar
I used Ceratec for the BMW Dave when I was swapping between the summer and winter wheels and found it bob on.
The Following 2 Users Say Thank You to nbray67 For This Useful Post:
camerashy (29-11-2018), Cookies (29-11-2018)
Old 29-11-2018, 10:22 PM   #8
AndyN01
I'm a fan of Corrosion Block grease (and ACF50 fluid) after many years of motorcycling.
For me, Corrosion Block is used where there's different metal to metal contact e.g. alloys to hub.
I use Ceratek on the back of pads (if needed - some have a "backing" bonded to the steel plate).
Wheel nuts/bolts have a squirt of engine/gearbox oil.
On Slider pins I use whatever is specified - if you can find out! For some cars it's moly grease, some it's lithium, some it's red rubber grease...... I guess Ceratek would generally be OK?
On most of my "problem" calipers it's been corrosion on the slide pins &/or lack of lube on the pins that's been causing the issues. That and garages just ramming the pads in and then wondering why the brakes are not coming off properly!
I, like many, have used copper grease for decades but I this is no longer recommended. I think there's a problem with the copper causing some damage to the ABS (?) sensors?
Looking forward to hearing more thoughts & suggestions.
Andy
PS. It's not as simple as you might think........
https://textar-professional.com/text...modern-brakes/
https://proslip.com/ceratec-brake-grease-what-is-it/
AndyN01 is online now   Reply With Quote
Old 03-12-2018, 02:15 PM   #9
\Rian
\Rian's Avatar
Andy
Been looking on http://www.acf-50.co.uk/marine.htm and corosion block it seams is not designed to be used in the manor your referring to.
Ceramic grease should be used in metal to metal contact its superior to moly grease, lithium, and red rubber grease and is safe for all applications as the frictions reducing material is a ceramic and therefore inert.
Lithium is a metal and can aid in galvanic corrosion not as bad as copper grease.
The ceramic grease has a higher melting point and therefore it makes sense to use it on hubs, wheel bolts etc.
I use it on just about anything when redoing a bolt up or mounting a wheel
Old 04-12-2018, 12:01 PM   #10
AndyN01
Thanks.
Maybe I've misunderstood.
From the website:
".....Corrosion Block – Is the Industrial / Marine version of ACF-50. The main difference being a marginally thicker film and better suited where there may be dissimilar metals (my highlighting) and / or salt water spray – so more suitable for Automotive/Marine/Industrial use...."
Hence I thought it ideal for the mating face between alloy wheels & steel hubs.
Regards,
Andy.
