Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > CarPro-Cquartz
CarPro-Cquartz CarPro, a leader in the pro detailing market, was established in 2009 by people who love their cars. We wanted to make great car care products available to other enthusiasts. Our progressive vision and advanced technology brought coatings, such as CQuartz, to the market when it was still unknown to the Western Hemisphere. CarPro was the original creator of Nanotechnology car detailing products and continue to bring new professional car detailing products and fresh ideas to the masses. From interior coatings and cleaners to our most well-known ceramic paint coating, CQuartz, we have something for every car care need. Your car deserves the ultimate protection and we offer the products that deliver professional results.
Old 16-11-2017, 12:21 PM   #1
CarPro.UK
Carpro UK
CarPro.UK's Avatar
Lightbulb New Release : CarPro ClearCUT - Rapid Cutting Compound
CarPro ClearCut - Rapid Cut Compound
Time is money... Save it!
Tired of spending countless hours cutting heavy defects out of the paint? Who isn't? For the past few years CarPro has been working towards creating a fast and heavy cutting compound, vastly more aggressive than any compound CarPro has produced before! The result is.... CarPro ClearCut! CarPro ClearCut is the compound you reach for BEFORE your finishing polish, such as Reflect! CarPro ClearCut was developed to QUICKLY remove defects whilst allowing you to easily view your work through the polish. Within 1-2 passes you can begin to watch the defects literally disappear before your eyes as the compound begins to become transparent. This allows you to continue cutting as needed OR stop as soon as the defects are removed and you find yourself ready for finishing polish. In some cases and with the correct combinations this incredible next-gen compound may also be used as a 1 step product!
CarPro ClearCut is an extremely fast acting liquid abrasive built from the ground up for efficiency, performance, and speed! Unlike other popular compounds on the market ClearCut doesn't fool you by swelling the paint or hiding water spots and scratches just to see them re-surface later! With NO fillers ClearCut wipes off fully and a simple Eraser wipe down EASILY removes any lubricants.
Unlike compounds of the past, CarPro ClearCut has its own method of application for optimal results... reversing the traditional "heavy to light" method, we start with lighter pressure and finish heavy! Additionally I find myself using a bit more compound with ClearCut than I do with traditional compounds. While ClearCut cuts like a Ginsu, it is also low dusting and wipes off with ease! Say goodbye to hours of wasted time and hello to efficiency and less labor costs!
Buy yours here today!
https://carpro.uk.com/products/clear...compound-250ml
https://carpro.uk.com/products/clear...compound-500ml
https://carpro.uk.com/products/clear...ompound-1000ml
Features:
  • Next-Gen Compound
  • Cuts FAST!
  • Saves time
  • Zero Fillers
  • Low dusting
  • Removes p1000 grit and up
  • Body shop safe
  • Compatible with both Dual Action and Rotary machine
  • Compatible with a variety of foam, microfiber, and wool pads
Specifications:
  • Size: 250ml
  • Color: White
Directions:
For Dual Action use:
  • Prime (clean dry pad) with a very thin worked in layer of compound and add an additional 3-4 pea sized drops of product
  • Spread product across section
  • Raise speed to HIGH speed with LOW pressure
  • Use MINIMAL pressure for first 2-3 passes increasing pressure with each pass
  • Increase pressure with each pass, finishing down with heavier pressure
  • When scratches are gone or polish has been worked through, wipe clean with microfiber towel
  • Clean pad
  • Move to next section -> Apply 6 - 8 pea size drops to pad and repeat steps 2-7.
For Rotary use:
  • Keep polisher on low speed with LOW pressure
  • Increase pressure with each pass, finishing down again with low pressure
  • Clean pad
Tips:
  • We recommend following with CarPro Reflect or Essence.
CarPro.UK is offline   Reply With Quote
The Following 4 Users Say Thank You to CarPro.UK For This Useful Post:
Audi m8 (11-06-2018), chongo (16-11-2017), tosh (16-11-2017), Yellow Dave (16-11-2017)
Old 16-11-2017, 12:23 PM   #2
CarPro.UK
Carpro UK
CarPro.UK's Avatar
Checkout a review and video here
https://www.facebook.com/michael.mcc...55179606396985
Kind Regards
Craig
Old 16-11-2017, 01:58 PM   #3
Now that is impressive. Might take some getting use to with no pressure at the start, but am intrigued why this way?
Old 16-11-2017, 02:10 PM   #4
CarPro.UK
Carpro UK
CarPro.UK's Avatar
It's a general thing we recommend with all polishes, to warm the lubricant slightly and not shock the abrasives.
We find this offers the best from clearcut.
It's also a good idea for ceramic abrasives, as going too hard too fast with a ceramic abrasive can cause it to shatter from sudden heat increase and lose the cut it once had.
The Following User Says Thank You to CarPro.UK For This Useful Post:
Derekh929 (16-11-2017)
Old 16-11-2017, 02:31 PM   #5
So it's a bit like Essence in a way start slow with less speed then increase speed. Look forward to trying it out
CarPro.UK (21-11-2017)
Old 16-11-2017, 06:48 PM   #6
LeeH
LeeH's Avatar
If you used Essence after this can you miss the wipe down? One reason why I love Essence is missing the IPA/Eraser step.
Old 21-11-2017, 11:03 AM   #7
CarPro.UK
Carpro UK
CarPro.UK's Avatar
Yes you can
Craig
The Following 2 Users Say Thank You to CarPro.UK For This Useful Post:
Audi m8 (11-06-2018), LeeH (22-11-2017)
Old 29-03-2018, 04:44 PM   #8
saxoboy07
saxoboy07's Avatar
Absolutely incredible Rapid Cut is the difference between using other polishes and this is phenomenal my go to polish for heavy cutting from now on via rotary
saxoboy07 is offline   Reply With Quote
The Following User Says Thank You to saxoboy07 For This Useful Post:
CarPro.UK (04-04-2018)
Old 29-03-2018, 07:36 PM   #9
Daniel Branco
Nice, more people tried?
Daniel Branco is offline   Reply With Quote
Old 30-03-2018, 12:28 AM   #10
saxoboy07
saxoboy07's Avatar
Not sure but i don't know why i haven't bought it before now its that good of a polish and makes my job easier
