Old 12-08-2017, 10:35 PM   #11
Originally Posted by hoggy90 View Post
Thanks chongo.
What do you recommend for decontamination of the paint? I've already got snowfoam and some new claybars?
Well before you start the decon a pre wash followed by a hand wash is required then I would get tar remover especially for the lower panels, it will be hard to see the tar because of the colour but they will be there then get some fallout remover then clay your car, depending on what clay you have, you will need some clay lube then once it's fully cleaned and decon then your ready to begin
Old 13-08-2017, 08:50 AM   #12
hoggy90
hoggy90's Avatar
Thanks chongo
hoggy90 is offline   Reply With Quote
Old 14-08-2017, 10:46 AM   #13
X-Type_Bobstar
X-Type_Bobstar's Avatar
Lovely car, it will look fantastic once its had the paintwork corrected. I would recommend trying S20, you can use a Scholl Orange pad or go to a burgundy pad for more cut. I've just done a friends Audi Q5 and that was grey, hard to see the swirls anyway but horrible to try and correct. Paint was hard as nails. The Meguiars microfibre pad plus S20 worked wonders on another mates 2yr old Audi A6. That was a darker grey, possibly Daytona grey? and looked immense when it was finished.
X-Type_Bobstar is offline   Reply With Quote
Old 14-08-2017, 12:08 PM   #14
percymon
This might be of interest..
http://www.polishedbliss.co.uk/acata...er-winner.html
Either way talking to someone like Polished bliss (admittedly still 3 hours drive for you) might point you to something that works reasonable easily, with decent results, for a novice.
Old 20-08-2017, 09:21 PM   #15
hoggy90
hoggy90's Avatar
Thanks mate I'll give that a go! I heard about scholl spider pads also? Have you heard of or used these?
Old 20-08-2017, 09:22 PM   #16
hoggy90
hoggy90's Avatar
Just had a look at the link percimon and it looks exactly like what I was looking for! Thanks mate
Old 12-09-2017, 10:45 AM   #17
norman1979
Did you manage to get the correction done on the S5?
My paint on my B7 is the same and in very similar condition so interested to know what you have used
norman1979 is offline   Reply With Quote
Old 21-11-2017, 02:33 PM   #18
meph137
Just for what it's worth (and perhaps to give some motivation!) I had a very similar scenario - I bought an Audi S4 which looked gorgeous but from what I can tell the seller (nice a guy as he was) had most likely used a filler to hide all the swirling from hand car washes, and also a very nasty deep scratch which I did not dare tackle myself so got someone else to do).
Anyway, I've never used a DA before, though I'm a fairly cautious and careful person and this was the result from about an hours work or so (which included using a fallout remover, a clay bar, drying and polishing). I found the DAS 6 easy to use, it was all in all quite enjoyable. Tip - listen to some music whilst doing it to avoid driving yourself mad!!
Sorry, it's a video - didn't take any stills.
https://youtu.be/3UtPDEHrF54
Edit - how do I show YouTube videos inline?!
meph137 is offline   Reply With Quote
Old 21-11-2017, 06:15 PM   #19
meph137
Didn't mention I used a DAS-6 pro, hex logic orange pad hc400, I did try pf2500 and it worked to a degree but needed more cut and cleanyourcar said that audi paint will need hc400 most likely anyway so i didn't feel shy of doing it.
didn't have a PTG though, which i probably should, so I've now bought one.
Old 21-11-2017, 07:50 PM   #20
derbigofast
derbigofast's Avatar
i agree with scholl line of polishes but contrary to belief i found working for audi all cars paint was individually harder or softer even on two cars that rolled of the production line one after the other so do your research and test paint hardness buy starting light and increase untill desired result appears s17 or if required s3 were some of my favorites while buffing new cars and used alike all day every day
