Old 10-10-2018, 01:43 PM   #1
Yulee
Gyeon Pure & q2 mohs
Hi guys,
trying to learn the Gyeon range - what's the difference in Gyeon Pure & q2 mohs.
also - After polishing a car with rupes yelow and yellow rupes fine polish would you panel wipe before coating?
thanks
Yulee is offline   Reply With Quote
Old 10-10-2018, 02:14 PM   #2
Arbo94
Not too sure about the first part of the question but I think on the Gyeon site you can compare the products in terms of hardness, slickness, durability etc (open to correction here)
To the second part, yes.
A panel wipe will help remove any polishing oils that could otherwise have a negative effect on the bonding of the coating/sealant/wax. If using Gyeon coatings I would lean towards using Gyeon Prep or Car Pro Eraser. You could also use an IPA, I tend to use both as I've heard panel wipe is different to IPA.
Hope that helps a little.
Arbo94 is offline   Reply With Quote
Old 10-10-2018, 02:47 PM   #3
ENEP
ENEP's Avatar
Basic difference: Pure is easier to apply and less durable. MOHS more durable and not as easy to apply.
For more details I recommend looking at both products on PolishedBliss, they have extensive product information and also great service if you need help before purchase.
https://www.polishedbliss.co.uk/gyeon-q2-pure
https://www.polishedbliss.co.uk/gyeon-q2-mohs
Old 11-10-2018, 11:20 AM   #4
toni
toni's Avatar
Send a message via Yahoo to toni
Gyeon MOHS is dead easy to apply, but requires multiple layers. I don't find it to bead as good as other ceramic coatings. Pure should have better water behavior and needs only one coat.
toni is offline   Reply With Quote
Old 11-10-2018, 01:51 PM   #5
euge07
euge07's Avatar
yes you will need to panel wipe before application, Gyeon recommend washing after polishing with a degreaser as well, Having applied Gyeon Pure before it is sticky to remove but there is a video in the gyeon section shows how to apply & remove as it is a different method to other coatings- beading and water behaviour and gloss levels are absolutely immense from Pure
I have read that MOHS is easier to apply
Old 11-10-2018, 09:34 PM   #6
Christian6984
Christian6984's Avatar
I found Gyeon Prime a nice easy one but don't think its available anymore since i used it in 2014. Was a good starting place for me into paint ceramics
