Old 23-08-2018, 07:25 PM   #1
CLCC
CLCC's Avatar
2nd Attempt at Wet Sanding
Following on from my 1st Attempt at Wet Sanding (http://www.detailingworld.co.uk/foru...d.php?t=407970) here is my 2nd Attempt at Wet Sanding.
https://youtu.be/NiU4_MLKnL0
Perhaps naively, I had thought that wet sanding with 1500, 2000, 3000, 5000 (by hand with a sanding block) and then compounding and polishing with 500, 2500 and 3800 with a rotary and foam pads would completely remove orange peel, but this wasn't the case for me.
I think it has greatly improved the orange peel, (and clarity) but not removed it entirely. Those who have much more experience with wet sanding, is that what would be expected with the above mentioned method and materials, or do you think there is something lacking in my technique?
Many thanks
Chris
CLCC is offline   Reply With Quote
Old 23-08-2018, 08:05 PM   #2
CLCC
CLCC's Avatar
Here are some stills.
Old 23-08-2018, 11:04 PM   #3
Christian6984
Christian6984's Avatar
something I've never done to remove OP, i was tempted with my Renault Clio being black and it was terrible for orange peel. I never did it as was in a stage where i took a step back from detailing and was between owning a machine polisher at that time, and hardly justifiable on a car like a Clio.
I think you have done a really good job, would be good to see some shots from a bit further away if you get chance, like down the side of the car maybe. You have massively improved it as you can see from the first photo with the wheelie bin in it
Just missed video, shows a bit more detail, looks good
The Following User Says Thank You to Christian6984 For This Useful Post:
CLCC (23-08-2018)
Old 23-08-2018, 11:55 PM   #4
Titanium Htail
Titanium Htail's Avatar
When op flatting, the key would be to get the surface flat, those peaks will show as dimples so working to get the surface constant will be challenging.
I have some numbers from bare paint to wet sand then cut then polish, which show the overall amount of clear removed, in just guessing unless you know the amount of initial clear you have will be a problem or opportunity for degrading the surface too far.
Justin Rose / Kevin Brown have some great wet sanding information on Utube I will try to post the link.
Wet Sand Measures
Bare Paint 5.16 t/mils
Sand 4.31
Cut 3.94
Polish 3.88
https://youtu.be/BgCmrGMhvss
John Tht.
Old 24-08-2018, 11:24 AM   #5
CLCC
CLCC's Avatar
Wet Sand Measures
Sand 4.31
Cut 3.94
Polish 3.88
John Tht.
Thanks, that was one of the videos that I watched before I started. I think with those kind of videos they tend to highlight the best bits, rather than any limitations of the technique. Or, for example, say if you are getting result x, try doing y. So that's why I'm not sure if I am naive in expecting OP "removal", rather than "improvement"
I watched the below video from Autogeek which claimed OP "removal" but there was still a LOT of visible OP at the end.
https://youtu.be/_Z1ZaF10nbo
Old 24-08-2018, 12:17 PM   #6
GSVHammer
GSVHammer's Avatar
Video 2 is better than video 1. I can now see a difference between the 2 doors. I've never wet sanded before. I don't think I would fancy doing a whole panel on my first attempt.
I'd try a spot repair though.
Good Job.
The Following User Says Thank You to GSVHammer For This Useful Post:
CLCC (24-08-2018)
Old 25-08-2018, 12:21 AM   #7
Christian6984
dont know if this one helps any more, stumbled on it last night somehow. Showed how OP could be levelled and how much clear is being removed by the 1500/3000/compound/polish stages
Mason (25-08-2018)
Old 25-08-2018, 02:52 AM   #8
david_h
I am lazy in that I cannot bring myself to go through the whole process of wetsanding but love the results. I did a bonnet once and it took me the whole day.
Recently I have tried using denim pads, and although they have improved the orange peel it is still there. I think the trick is not to use a foam backing pad so the pad hits the surface much flatter but I am still testing.
Great job and effort by hand though.
david_h is offline   Reply With Quote
The Following User Says Thank You to david_h For This Useful Post:
CLCC (26-08-2018)
Old 25-08-2018, 03:53 AM   #9
Titanium Htail
It's s bit like sanding headlights when you only know if you have gone sufficient deep at the end result.
Check out ChrisLarson Master wet sander global trainer. He uses only 3M plus wool chrislarsonautodetailing@gmail.com for his products he is the �� �� guy.
Larson Services.
Old 26-08-2018, 04:38 PM   #10
CLCC
CLCC's Avatar
Thanks. Yeah it's a very time consuming process! Perhaps I am wasting my time with the 2500 step. Or others say the 5000 grit step, but I was struggling to compound out 2500, so the paper set I brought for 3000 also included 5000 and 7000. I figured if I was struggling with 2500, that it was better to use 3000 and 5000, rather than 3000 alone.
I'm still working on my process, I think the 2nd Attempt was better and faster than the 1st. So hopefully the 3rd or 4th will be better. I reckon by the 5th I should be ready to charge money for doing supercars.
wet sanding
