Old 23-04-2018, 02:19 PM   #1
IDreamofGloss
Cost effective swirl finder for daylight
Hi,
I've just acquired a white panamera which is a beautiful machine but unfortunately in need of some fairly heavy swirl correction.
I've polished up a couple of cars before with a DA, maybe not to showroom zero swirls before but just about, but am quite hamstrung because I do not have a garage in which to undertake the correction.
I did tape off and correct a small square yesterday on the bonnet to see how it went, mainly 'cos I was desperate to get working!! it went well (have ordered some higher cut pads as took 5 passes without completely taking out swirls) but it was very sunny and no problem to see progress.
However, in daylight there is no sign of the defects or correction.
White's probably not the best colour to see defects in the first place either I guess... :/
I've seen various posts on here on 'sungun' alternatives and torches but the evaluation of them all seem to be based upon working inside. Is there any low cost alternative anyone can recommend suitable for outside use or am I restricted to working only when the sun is out which really is not doable for me?
Many thanks,
David
IDreamofGloss is offline   Reply With Quote
Old 23-04-2018, 02:44 PM   #2
AndyN01
Hi David,
Take a look here:
http://www.detailingworld.co.uk/forum/showthread.php?t=205820.
I've done this and it works perfectly well outside.
Good luck.
Andy.
Old 23-04-2018, 03:09 PM   #3
\Rian
\Rian's Avatar
any suggestions for something of the shelf.
Not everyone want to make one or has the time to make one !
Old 23-04-2018, 03:21 PM   #4
ttc6
I've just picked up a Sealey Colour Match LED (065):
It's only 10w, but they do a 20w and a 50w. Mine is borderline strong enough to use outdoors. Nicely built too.
ttc6 is offline   Reply With Quote
Old 23-04-2018, 05:11 PM   #5
Leebo310
Leebo310's Avatar
Get one of these from Amazon
Q5 3W Led 350 Lumens mini Flashlight Zoomable Torch AA
Cheap as chips and show's up defects very well. White is really hard to see, you'll need to play around with the angle of the light and distance from source to spot defects but it is possible.
It'll also help massively if you remove all other light sources and just use the led flashlight. For white or silver cars, I'll turn the lights off in my garage and just use the flashlight or a head mounted similar led one (can't find the link for this one)
Think Larry from Ammo detailing did a YouTube video where he discussed the struggle to get defects to show on white and advised removing all other light sources.
Edit - just reread your post that said you don't have a garage so obviously quite hard to remove additional light sources!
Old 23-04-2018, 05:46 PM   #6
Marve
Marve's Avatar
If only there was some way to take the sun away for 8-10 hours or so every day...
He'll have to give up sleeping!
Marve is offline   Reply With Quote
Old 23-04-2018, 05:56 PM   #7
\Rian
\Rian's Avatar
Norway
How do you know he doesn't live in Norway where they have the sun out at night!
Old 23-04-2018, 10:59 PM   #8
IDreamofGloss
hehe, maybe I should move to Norway, probably cheaper option than buying a sungun!
Thanks guys but still looking, I just saw this more powerful version of the one in the earlier post albeit it was still based on internal inspection.....
https://www.sitebox.ltd.uk/sealey-le...osealey_LED066
just cant see how a 20w bulb outside will even register on the car paintwork and show defects?
Old 23-04-2018, 11:25 PM   #9
voon
voon's Avatar
Hm, why are people so much into the expensive high CRI lamps? What do people care about colour matching, if all you do is detailing? I can only imagine this to be of any importance to a painter who needs to see exact paint coours or something. or am I missing something? Why isn't a proper good strong high-kelvin (6000+k) LED all you need?
Old 23-04-2018, 11:44 PM   #10
ttc6
A 20w array of LEDs gives you a lot of lumens. If you can wait until the weekend I can organise a picture of my 10w version outdoors on some silver paint for you? I'll even throw in the swirls for free.
I understand your point completely. For me though it was £40 (much less than RRP on these) for a decent, well built, rechargeable work light - which is about the going rate. The colour matching ability added less than £5 to the cost so was a nice benefit.
The Following User Says Thank You to ttc6 For This Useful Post:
Pad (29-04-2018)
