Old 29-07-2016, 07:30 PM   #21
Kev_mk3
Kev_mk3's Avatar
Send a message via MSN to Kev_mk3
Cracking work
Kev_mk3 is offline   Reply With Quote
Old 30-07-2016, 07:16 PM   #22
Poobah
Poobah's Avatar
Bit more done. Classic corrosion spot just behind where the inlet resonator box goes inside the front arch. Took it apart and this one isn't bad at all. Just a light bit of surface corrosion which further enforces that this appears to be a good one.
So, usual process. Grind/sand the corrosion off then Hydrate 80 followed by Epoxy Mastic.
Poobah is offline   Reply With Quote
The Following User Says Thank You to Poobah For This Useful Post:
SBM (31-07-2016)
Old 01-08-2016, 08:14 PM   #23
Poobah
Poobah's Avatar
Had a spare half hour this evening so stripped out the passenger side front arch to see what we're dealing with.
Generally decent. A little surface corrosion around the mounting points for the arch liners (as there was on the drivers side) and some surface stuff on the top of the spring seat. All sortable pretty easily.
Getting happier the more I see of this car.
Old 01-08-2016, 10:40 PM   #24
Poobah
Poobah's Avatar
Originally Posted by Kimo View Post
U.K. Spec ftl
Thanks for your constructive post...........
gatecrasher3 (02-08-2016)
Old 02-08-2016, 12:05 AM   #25
4d_dc2
Awesome. Check out tegiwa for any oem honda parts or any aftermarket parts you will ever need.
4d_dc2 is offline   Reply With Quote
The Following User Says Thank You to 4d_dc2 For This Useful Post:
Poobah (02-08-2016)
Old 02-08-2016, 08:14 AM   #26
Poobah
Poobah's Avatar
Thanks for that. Didn't realise Tegiwa did OEM parts. Will check it out.
Old 02-08-2016, 01:21 PM   #27
Kimo
No worries
Just such an ugly front end compared to jdm
Kimo is offline   Reply With Quote
Old 02-08-2016, 03:13 PM   #28
Poobah
Poobah's Avatar
No worries
Each to their own. The UKDM model was the model I grew up seeing so it's the one I wanted. You also can't see the front end from the drivers seat which is the best place to be with one of these.
Old 02-08-2016, 10:08 PM   #29
Poobah
Poobah's Avatar
Bit more tonight. Usual story on the products. That's the two front arches done.
Old 04-08-2016, 09:38 PM   #30
Poobah
Poobah's Avatar
Minor update. Arch liners back in tonight.
I also did a little side job tonight on the rear upper strut brace. The standard colour is silver and mine was pretty scratched therefore I've refinished it in VW Carbon Steel Grey. Not 100% OEM however it does match the mounts of the front brace.
dc2, honda, integra, restoration
