Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Power Maxed
Power Maxed We are a company based in the UK with a great deal of experience in this market sector and we specialise in bringing products such as Power Maxed, Diesel Turbo Cleaner, Steel Seal & J-B Weld to market
Old 30-10-2016, 05:17 PM   #1
Hereisphilly
Hereisphilly's Avatar
Detailingworld™ Review - Power Maxed Tsunami
Introduction
Tsunami has been on my radar for a while now, ever since release, so when it popped up on offer celebrating PM's involvement in BTCC, I couldn't say no, so stumped up the cash and it arrived a few days later
The Product
Presentation wise this wax is spot on, it comes in a black presentation box with an MF applicator.
The pot is matt black and I think it looks amazing. The wax itself is very hard with a bright yellow colour and lovely marzipan scent
I was keen to see how the massive durability claims stacked up, as I don't think I have ever seen a wax with this longevity. I normally halve the amount of time manufacturers claim durability for, and this is generally a good indication of how long it will last until i'm unhappy with performance. Even doing so, 9 months is nothing to be sniffed at
The Manufacturer says:
Tsunami is a real enthusiasts wax, no added gimmicks just a hard working and durable wax. Tsunami protects against UV so good for the summer months, and stands up to rain, snow, salt, dust and grime so is perfect for a winter wax when you need that extra protection.
With the latest coating technology we bring you a unique wax blend. We have created the finest grade polymer wax together with Si02 technology. Applying this wax is extremely effective, wrapping your painted surface in a wax / nano coating, bonding effectively into a super protective and durable barrier.
The Method
Full disclosure; this review took place over two weekends, as PM assisted with the initial issues I had, which I will go into more detail now
The car had been washed with the usual 2BM, dried and cleansed prior to application. I had done my full winter decon routine 2 weeks earlier.
I'm normally not used to applying waxes with MF applicators, having always preferred and used foam ones. The website recommends the use of a foam one, so instead of using the included MF app, I reached for an AF waxmate (cut down to fit)
I quickly found this to be the wrong type of applicator. The wax was extremely grabby to apply and due to the height /softness of the app, i found it would bog down on the paint and deform too easily as i tried to pull it along
I quickly switched out to a traditional type of flat disk app, and this was much better, but still the wax felt quite grabby. Dampening this aided in smoothing out the process.
In order to combat the grabby nature, I felt I had to keep loading up the app, but I knew this wasn't helping in the long rung, as over application was easy in places, especially horizontal panels
Due to the colder temperature I left the wax to cure for the full 10 minutes before buffing (as per instructions).
Buffing off required a bit of an arm workout, as the initial stage is grabby again, but it does remove fully and easily after that
I could see in places that there were some mild wax holograms in places, so a second pass with a cloth sorted these. This can again be chalked down to over application
The finish on the car was really good though!
In person it looked hard and glassy, more like how a sealant is, than adding warm depth like a traditional wax
I like both so this wasn't a problem, but trying to show this in pictures was quite hard
And as I was packing it all away, it started to spit (typical), but I was looking forward to the beading, and it didn't disappoint
Now I wasn't thrilled with the difficult application so discussed this with Power Maxed and basically was told that using an MF app would yield better results and should be much easier to apply = can be applied thinner = less grabby to remove = less holograms
I had a go with that method this weekend and can confirm a much better experience, so I'll be using only MF for this wax in future
Price
The pot, box and free applicator has an RRP of £49.99, and can be bought from PM direct with free shipping
http://www.powermaxed.com/clean-your...er-wax-tsunami
A price of £50 is pretty much what I would have expected and suits the market. If the durability claims can hold up then i think its well worth the money, as performance is definitely up there, in both looks and water behaviour
At the offer price of £30 that I paid, this is an absolute bargain!
Would I use it again?
Yes, now that I have resolved the application issues, I will definitely be using it again
Conclusion
If you want a wax that smells great, looks amazing in its presentation (dat matt black pot) and performs well, then look no further.
If the durability claims hold true then this wax is great all rounder, as it's glossy as hell for the warmer months, but then beads and sheets well in winter
Application is much easier using the included MF applicator and i think it would do PM well to update their website with the same, so as to not mislead people by recommending foam.
Other than that it's a thumbs up from me
Hereisphilly is online now   Reply With Quote
The Following 8 Users Say Thank You to Hereisphilly For This Useful Post:
BMW - AL (16-08-2017), Brian1612 (30-10-2016), Citromark (02-11-2016), Juke_Fan (30-10-2016), Luke M (30-10-2016), OvEr_KiLL (30-10-2016), Power Maxed (01-11-2016), Yellow Dave (30-10-2016)
Old 30-10-2016, 07:36 PM   #2
Yellow Dave
Yellow Dave's Avatar
Thanks for the review. It's a wax that's been in my basket for a while now, but also considering the new ginger bread man version
The Following User Says Thank You to Yellow Dave For This Useful Post:
Hereisphilly (30-10-2016)
Old 30-10-2016, 10:13 PM   #3
Scrim-1-
Scrim-1-'s Avatar
Nice review again Phil.
Tried this wax yesterday on both Mf and foam applicator, deffinatly more pleasurable with a Mf applicator.
Scrim-1- is offline   Reply With Quote
Old 01-11-2016, 08:39 AM   #4
Power Maxed
Dw Sponsor
Power Maxed's Avatar
Thanks for the write up, great review thank you
Power Maxed is offline   Reply With Quote
Old 03-11-2016, 08:35 PM   #5
robbo51
robbo51's Avatar
I recently fully detailed two cars and finished them with Tsunami
The application and observations are exactly as I found it
Overall...a great wax with a superb finish
Both cars:
Both clients have been impressed by the durability...August to now...Still beading well
robbo51 is offline   Reply With Quote
Old 03-11-2016, 09:08 PM   #6
Hereisphilly
Both cars:
Cracking shine on that XF 👍
Did you use the mf app too?
Old 03-11-2016, 09:25 PM   #7
robbo51
robbo51's Avatar
I used a foam applicator and dampened it as I progressed
It was warm day, but as PW state, temperature doesn't affect its application or removal
But I applied and buffed off each panel at a time...but I reckon the whole car could be done and will still buff off ok
Main reason I used it that day was the sunshine I couldn't get out of.
Ordered their Gingerbread too...Same stuff but smells different
Old 27-07-2017, 07:44 AM   #8
Rotiform
Rotiform's Avatar
How is the durability on Tsunami wax?
Rotiform is offline   Reply With Quote
