Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Gyeon
Gyeon Gyeon offers a range of premium quality products thoroughly tested to satisfy the needs of car detailing enthusiasts, as well as the exacting requirements of professionals. At Gyeon, we spare no effort or expense to provide you with the most innovative solutions, always producing exceptional results and ensuring your satisfaction.
Old 04-03-2015, 04:23 PM   #1
Gyeon Jeremy
DW Sponsor
Gyeon Jeremy's Avatar
02.2015 - NEW PRODUCT LAUNCH - Q Booster
Q Booster is probably the most exciting new product we launched for every insane-hydrophoby lover. Why is it so special? Because it's a special, ultra-innovative, fluorine based top-coat for every SiO2 coating, including those outside of the Gyeon range, that provides not only more durability of the base coat, but also very, extremally high hydrophoby/beading.
If you like Q2 Prime, Q2Mohs or any other quality glass coating (also outside the Gyeon range), you can easily prolong its hydrophobicity by 6-12 months!
NEW ULTIMATE HYDROPHOBICITY BOOSTER
Q Booster is the most versatile top-coat designed and formulated for quartz/ceramic coatings. It enhances water beading in a spectacular way, preventing fresh coatings from developing stains or waterspots whilst increasing overall durability. Ideally applied straight after your chosen quartz coating, (or at least within the first 4 weeks or in other words, before any contamination settles on the paint) this product is very easy to use and provides amazing results.
TOP-COAT FOR ALL SIO2 COATINGS
Q Booster is the easiest way to get the most out of your choice of coating, whether it is Q Prime, Q Mohs or even a coating outside the GYEON range, you can increase the durability and hydrophobicity in a massive way. Q Booster is not a stand-alone product, it only works as a top-coat for previously applied real quartz or ceramic coatings.
SUPER-HYDROPHOBIC PROPERTIES
If you love extreme beading, Q Booster is the finest product on the market to achieve this. It generates extreme hydrophobicity when paired with GYEON quartz coatings, reaching a contact angle of up to 120".
LONGEST-LASTING BEADING OF A COATING
We're not afraid to say, that Q Booster is the longest-lasting beading top-coat in the world. Used on a quality quartz coating like Q Prime or Q Mohs, it will prolong total beading by up to a further 12 months.
Gyeon Jeremy is offline   Reply With Quote
The Following 4 Users Say Thank You to Gyeon Jeremy For This Useful Post:
Gleammachine (05-03-2015), greymda (05-04-2015), R14CKE (05-03-2015), Short1e (10-03-2015)
Old 04-03-2015, 04:55 PM   #2
B17BLG
B17BLG's Avatar
Looks awesome!
Shame you have marketed the product on a poverty spec car.......
B17BLG is offline   Reply With Quote
The Following User Says Thank You to B17BLG For This Useful Post:
Gyeon Jeremy (04-03-2015)
Old 05-03-2015, 09:20 AM   #3
Gleammachine
Gleammachine's Avatar
Location: Chafford Hundred, Essex RM16, Essex & the South East since 2003.
Look forward to this, excellent.
Gleammachine is offline   Reply With Quote
Old 09-03-2015, 03:04 PM   #4
7MAT
Approved DW Trader
7MAT's Avatar
We have just received a small quantity of Gyeon Q2 Booster by Air-Freight today!
I don't imagine stock will last long so you'll need to be quick - but don't worry we have another much larger shipment on route to us via Sea-Freight.
Matt
7MAT is offline   Reply With Quote
The Following User Says Thank You to 7MAT For This Useful Post:
R14CKE (09-03-2015)
Old 12-03-2015, 05:23 PM   #5
BikerBob
Question
Interesting looking product however instructions seem to be adamant that application must take place within 2000km of original base coating? Is this perhaps a bit limiting?
I suppose there is a danger that contaminants might build-up on the base coat and poor prep before using Booster might limit its performance and subsequent benefits?
Regards Bob
BikerBob is offline   Reply With Quote
Old 13-03-2015, 12:36 AM   #6
Gyeon Jeremy
DW Sponsor
Hi Bob!
That's the most obvius reason - if any contamination occures, it makes no sense to use a top coat. It won't either bond properly or give the expected effect. 2kkm is limiting and it's meant to be. On the other hand, we've got CanCoat in the range, you can use it as a top up anytime you like
The Following User Says Thank You to Gyeon Jeremy For This Useful Post:
BikerBob (13-03-2015)
Old 13-03-2015, 04:25 PM   #7
nicky1975
If i coat first with prime or mohs, how long do i have to wait intill i top coat with booster?
nicky1975 is offline   Reply With Quote
Old 04-04-2015, 11:20 PM   #8
Andrew Byrne
Andrew Byrne's Avatar
I used Gyeon Booster today and it was a disaster it just evaporated in to
nothing was very unworkable. I gave my car 2 coats of Mohs first and followed
the instructions to the book, has anyone else tried it and if they have how did they find the application.
Andrew Byrne is offline   Reply With Quote
Old 05-04-2015, 12:08 PM   #9
Dibbuz
Dibbuz's Avatar
It's a mind problem. You don't see it but you are applying product. You can feel it in the slickness. Use the same amount as you would use Prime or Mohs.
The "tail" you see is evaporating but after that you are still spreading product. There was no other way to get it more visible without losing the awesome proporties of Booster.
When you touch the cloth you can feel is moist and not dry (evaporated). Like I said, it's more of a mind problem than a product problem.
Dibbuz is offline   Reply With Quote
The Following User Says Thank You to Dibbuz For This Useful Post:
Andrew Byrne (06-04-2015)
Old 05-04-2015, 09:55 PM   #10
Gyeon Jeremy
DW Sponsor
Yep, that's probably the only drawback Booster has. You have to use a lot of imagination and visualize where you've already applied the product. Don't worry - it will work properly despite the fact it was hardly visible during work.
