Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > G3 Pro
G3 Pro Farécla Products Ltd is a UK, family-owned company, manufacturing surface finishing products which are used on a wide variety of substrates. From compounds and applicators, to paint cups and microfibre cloths, Farécla has provided surface finishing solutions to automotive bodyshops, valeters, boat builders, wood workers, composite manufacturers and other industrial applications since 1952, now in over 120 countries.
Old 12-12-2013, 10:51 AM   #1
Farécla Trade
Farecla UK
Farécla Trade's Avatar
G3 Paint Renovator is the Winner!
Thank you to Classics Monthly magazine which has just made Farécla's G3 Paint Renovator the Winner in its Paint Restorers Test - with an outstanding 9 out of 10!
Farécla Trade is offline   Reply With Quote
The Following User Says Thank You to Farécla Trade For This Useful Post:
chillly (27-05-2014)
Old 25-05-2014, 06:19 PM   #2
D95GAS
any advise on the best way to use this product, I have just purchased a bottle. Also wanting to know if it can be machined on?
D95GAS is offline   Reply With Quote
Old 27-05-2014, 03:52 PM   #3
Farécla Trade
Farecla UK
Hi D95GAS,
As on previous thread, G3 Paint Renovator has been designed to be applied by hand with the white Waffe Applicator Pad. You get a great finish this way and do not run the risk of damaging your paint.
You can also use an orbital drive polishing machine to apply it, however we would only recommend you do this if you are trained and/or experienced in using one otherwise you do run the risk of creating damage.
If you are going to use a polishing machine, you can use it up to a speed of 1800rpm. We would however recommend you start at a 1200rpm and work your way up if necessary. Remember to keep the area moist with frequent mists of water.
We hope that helps!
The G3 Pro Team
farecla, g3 paint renovator, oxidisation removal, oxidised paint, paint renovator
