Old 11-10-2018, 01:31 PM   #1
atomicfan
Interior full of mold after applying Gtechniq Leather
I applied about 3-4 months ago Gtechnig Leather on the leather seats (The seats havent been cleaned)
Not after 3months (The car sits in garage with a few others) the interior, leather, caprets are full of mold
Any tips on how i can remove it from the whole interior and how to prevent it from mold again?
The windows are opened a little bit
Is a normal apc sufficient with wet vac or special cleaner and tools?
atomicfan is offline   Reply With Quote
Old 11-10-2018, 02:00 PM   #2
\Rian
\Rian's Avatar
To remove the mold APC then Autosmart Bio BRISK
To prevent mold, you can make some home made damp traps with Silica crystals, cheapest way to buy them is silica cat litter
https://www.wilko.com/en-uk/wilko-si...E&gclsrc=aw.ds
Fill some trays like a paint roller tray with a decent amount and put in the foot wells etc
and you can also get some hanging damp traps
mirdif64 (11-10-2018)
Old 11-10-2018, 03:54 PM   #3
atomicfan
Thanks for the info.
So normal cleaning with apc the leather and then spray on bio brisk on the leather?
On the plastics just wipe it down with a damp microfiber and some apc and spray on biobrisk?
The interior like carpekts clean with a microfiber and apc and vacuum it or how should i proceed?
Old 11-10-2018, 04:30 PM   #4
\Rian
\Rian's Avatar
Bio Brisk is intended for fabrics, you should use an extractor or wet vac to remove the spores, wiping the fabric and carpet simply wont be good enough, then once that's done spray BIO BRISK on all fabrics, it has active enzymes so you will need to leave it damp over nigh then use an extractor or wet vac again to remove the residue.
YOu can wipe down the plastics with APC no bio needed
Carpets and Fabics
1) vacuum
2) clean with wet vac or carpet extractor using APC
3) spray BIO BRisk on all carpets and fabric leave over night for the biological enzymes to do their thing.
4)clean with wet vac or carpet extractor using a carpet shampoo
Old 11-10-2018, 04:41 PM   #5
Shiny
DW Forum Sponsor
Shiny's Avatar
The only downside to Bio Brisk is that your car ends up smelling like an old people's home. Wish it had a nicer scent.
Lloyd
Shiny is online now   Reply With Quote
The Following User Says Thank You to Shiny For This Useful Post:
Ultra (11-10-2018)
Old 11-10-2018, 04:45 PM   #6
\Rian
\Rian's Avatar
One of the reasons I recommended a second wetvac / extraction
Old 11-10-2018, 07:13 PM   #7
Ultra
Ultra's Avatar
After removing the mold buy a couple of the moisture trap units that are advertised on tv pop one in each foot well and keep the windows SHUT, empty the units when needed and repeat. An open window will only allow more damp air in hence keeping the windows shut.
Ultra is online now   Reply With Quote
Old 12-10-2018, 12:41 PM   #8
smarty5927
I've used this anti-bacterial cleaner from Raceglaze to good effect on mold that was appearing on the inside of the hood of my car when it was not used for a while.
http://www.raceglaze.co.uk/car-care-...erial-cleaner/
Seems to kill off the spores ok and doesn't leave any unpleasant smells behind.
John
smarty5927 is offline   Reply With Quote
Old 12-10-2018, 02:58 PM   #9
Demented
Oil of Clove; a few drops mixed with water in a spray bottle & spray a very fine mist onto fabric and allow to dry.
Used it for years when mold appears, on velour interiors, seatbelt fabric and carpets and without issues; you have to clean away the mold first
However, only ever used it on leather once, on a leather steering wheel and the gaitors, the solution still worked and stopped the mold reoccurring but I had to dry the steering wheel with kitchen towel.
I was advised, I should of used white vinegar on the leather.
I still have the car, its been in my garage for 5 years and the mold has never reoccurred.
Try the Oil of Clove/water solution on an inconspicuous area of leather first, for peace of mind.
Demented is offline   Reply With Quote
The Following User Says Thank You to Demented For This Useful Post:
percymon (12-10-2018)
