Old 14-02-2018, 10:07 PM   #1201
huxley309
It's good, it does have a flower shaped spot but goes right down to firefly so only a few lumens, good if your intention is a sun gun. It ramps up the brightness, much like a dimmer switch.
Also all the modes are fully programmable to your liking, and it comes with a spare set of o-rings.
Very good flood with an even spill, I tried it when it was getting dark, really picked out any imperfections.
I haven't had it long to really test it, but so far I'm pretty happy with it.
Also £60 is a bit rich, they can be had for £40 when on offer just make sure you use good button top cells, like Samsung 30q.
You can run this torch on just the one cell, as they're all run in series.
Also run in turbo doubles up as a very useful hand warmer, and has a thread for tripod mount.
Old 15-02-2018, 11:28 AM   #1202
Itstony
Itstony's Avatar
Thanks for the response.
The only issue is the reflector which you confirmed. I would prefer smooth.
I am considering this HaikeLite MT07S XHP70.2 which has a smooth reflector, plus 4800K temp.
The one you have seems a better size though.
Old 05-03-2018, 10:09 PM   #1203
huxley309
Well gone and ordered a headlamp, not sure I can post Amazon links, so anyway it's this one.
TOOGOO Super Bright 3000LM COB Outdoor LED Head Light Lamp Torch Headlight
3K Lumen from a cob I find very doubtful, but with no reviews I've taken one for the team, that and it's just shy of £7.
Takes 18650 cells as you'd expect.
Old 06-03-2018, 12:08 AM   #1204
Ruairi
18650 cells? Wonder if I can modify my vape 🤔😂
Ruairi is offline   Reply With Quote
Old 06-03-2018, 03:02 PM   #1205
huxley309
Well I am putting 30q cells into it
Old 19-03-2018, 05:47 PM   #1206
huxley309
Right got my lamp, for what seven quid it's quite a fair bit of kit, bit weighty but did sit on my bonce fine.
Don't like the rubber battery cover, feels very flimsy but won't be the end of the world of it breaks.
Will fire it up later.
Edit - Fired it up, ok this is more like it a near perfect spread of light and Very bright.
Recon this is the perfect detailers lamp.
Old 19-03-2018, 10:12 PM   #1207
SwordfishCoupe
Looks like it will keep your head warm in the cold weather as well! 🤣
SwordfishCoupe is offline   Reply With Quote
The Following User Says Thank You to SwordfishCoupe For This Useful Post:
huxley309 (19-03-2018)
Old 19-03-2018, 11:18 PM   #1208
huxley309
Yeah tell me about it, not to mention I'm using unprotected cells should they ever decide to go..........
