Old 05-10-2018, 11:45 AM   #1
euge07
euge07's Avatar
servicing a machine polisher- vertool force drive
I use my vertool force drive an awful lot and on the last car I was machining this week I could barely hold the polisher as it was pulling and I think it needs the bearings greased perhaps- I have it 6months and never serviced it
Has anyone a good tutorial or video link they could share to service the machines?
Old 05-10-2018, 12:14 PM   #2
GSVHammer
GSVHammer's Avatar
Brian from Apex detailing has a generic video, he services all his own polishers.
Let me know how you get on as I have the same machine. I think a better quality of grease will help.
The Following User Says Thank You to GSVHammer For This Useful Post:
Simonrev (05-10-2018)
Old 05-10-2018, 02:07 PM   #3
euge07
euge07's Avatar
thank you for the video mate, will study it over the weekend and try get a chance to service it,
Old 05-10-2018, 02:54 PM   #4
Andy from Sandy
Andy from Sandy's Avatar
If it is a work horse tool you use pretty much every day then once a year you should change the brushes and clean out the carbon dust.
As they wear so the machine will run hotter.
Old 05-10-2018, 05:01 PM   #5
euge07
euge07's Avatar
What I noticed was the machine was hard to handle and trying to pull away etc never had an issue before hand and its normally easy to handle
Old 05-10-2018, 05:20 PM   #6
Sh1ner
I'm glad he does not service mine.
Bevel gears require specific lubrication and I doubt Flex would have chosen something unsuitable and what is in there is not contaminated there is no reason to change or recommend a change.
It will generally be a softer grease, as shown in the Flex, that is used because the gears require constant lubrication and are actually better run in oil rather than grease but leakage issues can be a problem, so a runny grease is used that flings and fills the gear teeth with lubricant but does not leak from the case.
All my Flex tools are years old, work as on day one, and have not required any servicing for grease starved, worn bearings etc. That is not to say the Vertool might not have issues.
I'm not sure what you mean by pulling but it does not sound like a gear related problem
If it is faulty and only six months old I would send it back, let them check and if necessary replace it rather than take it apart yourself.
That is a standard wheel bearing grease he is using in the video and its operation is different to that of a polisher with that internal mechanism.
Old 05-10-2018, 06:39 PM   #7
DavieB
DavieB's Avatar
Pulling sounds more like a pad /polish /paint combination interface issue. Noisy or vibrating / rattling /speed variation might indicate machine needs servicing.
Have you tried it on another car?
Only other thing does it have a counter weight that has become dislodged /moved?
DavieB is offline   Reply With Quote
Old 05-10-2018, 07:03 PM   #8
Tykebike
Tykebike's Avatar
If you bought this machine new then it should be covered by Festool's free return to base warranty (3 years).
Tykebike is offline   Reply With Quote
Old 05-10-2018, 08:23 PM   #9
fatdazza
OP’s machine is Vertool not Festool
Old 05-10-2018, 09:41 PM   #10
euge07
euge07's Avatar
Same pad and polish combo I use on most cars, To me it feels off balance so what you are suggesting sounds possible. Wonder is there somewhere I could send it to be looked at properly
