Old 17-10-2007, 02:28 PM   #61
Epoch
Epoch's Avatar
Originally Posted by Miracle View Post
Arrr the pig tails, what new Astons come with fresh from the factory!
So far when finishing with the 4000 we've been fairly successful at not leaving any.
Although some initail test patches did show signs around the edges where we hadn't worked it evenly enough.
Epoch is offline   Reply With Quote
Old 17-10-2007, 03:50 PM   #62
CleanYourCar
Approved DW Trader
CleanYourCar's Avatar
I should read all the post first
I might ahve to have a go by PC now!
Victoria Wax - Dodo - Meguiars - Menzerna + Many More!
CleanYourCar is offline   Reply With Quote
Old 17-10-2007, 03:55 PM   #63
Epoch
Epoch's Avatar
You could, and others have depends on the throw of the PC really.
Don't use too much water either
If your gonna stock them Tim the cheapest i can find is £22.00 plus VAT for a box of 12
Old 17-10-2007, 05:14 PM   #64
Affection to Detail
Affection to Detail's Avatar
So is it best to steer clear of the random action and stick with a pure rotary motion?
I assumed that a random action would give a better finish but I can understand the comment out pig tails etc being an issue.
I have a plethora (sp) of compressors and air tools, never seen one having the benefit over another, except when using water.
Electric version would save having to lug around a compressor though. Will give a few more options a try. Dont think any of my electric versions have a pure rotary function on them though.
What sort of rpm etc does the Mirka run at?
Any more input welcome.
Affection to Detail is offline   Reply With Quote
Old 17-10-2007, 05:29 PM   #65
Epoch
Epoch's Avatar
^^ No you do need DA
If you have too much motion it can cause large arcs around the edge. So you want a small throw DA action for finner sanding.
Splashing the water about is the only benefit with the priciple.
Old 17-10-2007, 05:30 PM   #66
talisman
talisman's Avatar
Send a message via AIM to talisman Send a message via MSN to talisman
is it possible to have a few links posted up for few suppliers please???........
talisman is offline   Reply With Quote
Old 17-10-2007, 05:49 PM   #67
L200 Steve
Regional Organiser
L200 Steve's Avatar
I feel that the short throw of the Mirka is the way forward in comparision to the much longer throw of certain R/O sanders (the PC included).
From experience of sanding many different coatings over the years with various items of equipment, I've come to the conclusion that the longer the throw of the random orbit, the better the tool is suited to the more aggresive of abrasives. I know that the PC is good at removing large quantities of paint when used with 60 grit discs
The speed of the Mirka is fully adjustable, similar to the PC. Jon and I only ran it on the lower end of the speed range, though I do feel that the quality of finish left would improve by running the machine at a higher speed. This is something that I would like to try next time I use Jon's machine.
I think that the random orbital action of the Mirka suits the finish better than a rotary action would. I've seen people dressing aluminium sheet using a rotary sander, leaving behind a shell effect. Same again though, I'm interested in trying out this theory first chance that I get. I know that you can get those little 4" air rotaries from Farcela etc for next to nothing.
L200 Steve is offline   Reply With Quote
Old 17-10-2007, 07:50 PM   #68
Epoch
Epoch's Avatar
^^^ I'm gonna need a bigger compressor then!!!
Old 17-10-2007, 09:07 PM   #69
Auto Finesse
Auto Finesse UK DW Supporter
Auto Finesse's Avatar
steev the fracla polishers are random orbital i have one they are good for small parts like bumper grills ... i have just got a full size air roto to im only just getting used to it but it is so much lighter than a lecy one.... only thing is you need a big air comp to run two full time i have a hudravaine its huge and can run loads of stuff at the same time
i have the fracla rep coming to the place where i work soon to show so new kit and stuff might be interesting, or not
Auto Finesse is offline   Reply With Quote
Old 17-10-2007, 10:35 PM   #70
Craigsax
Craigsax's Avatar
looks like the Rubbish boys original edition, is doing pretty well john....
A coat was applied to the bonnet
Craigsax is offline   Reply With Quote
