Old 16-04-2018, 09:53 AM   #1
BruceVolvo
Hoselock Ultimate Hose
Hi
Has anyone got/used the hoselock ultimate hose, is it as god as the adverts says ie no kink, no twist, lightweight etc? As I suspect my current ancient garden hose is the cause of my intermittent pressure problems on my pressure washer.
Bruce
Old 16-04-2018, 10:05 AM   #2
Hi, yes I’ve got the Ultimate hose (yellow one). Works very well, I’ve not had any kinks from it, also I’m getting more water / pressure through it than my ancient hozelock pipe it replaced last year.
Hope it helps
A
BruceVolvo (16-04-2018)
Old 16-04-2018, 10:11 AM   #3
BruceVolvo
Any ideas on the best place to buy from Amazon and Argos seem to be the best so far at £32.99 for the 30m hose
Old 16-04-2018, 11:54 AM   #4
spyk3d
Have you considered the Hoselock Tricoflex hoses?
Amazon seems the best place to get them at a reasonable price.
spyk3d is offline   Reply With Quote
The Following User Says Thank You to spyk3d For This Useful Post:
Old 16-04-2018, 12:04 PM   #5
I picked mine up from Wickes - at the time they were a couple of ££ cheaper, but local store had one in, so no postage and could get there and then.
Obviously try all DIY stores, Argos, Amazon and I think I found them for sale a garden centres on line very competitive priced, but none local to me...
Old 16-04-2018, 12:31 PM   #6
neilmcl
The Fitt NTS hoses are very good for not kinking.
https://www.screwfix.com/p/fitt-15m-...ech-hose/4592j
Although check out Aldi/Lidl because they occasionally sell the same thing made for them by the same manufacturer. I got one last year and apart from the colour it's identical the one above.
EDIT: I just found this - https://www.aldi.co.uk/gardenline-ga...95742202810200 , it states that it's an NTS hose so may be worth popping in to check it's made by Fitt.
Actually just checked myself and it is. Decent 20m hose for just £9.99, result
The Following 2 Users Say Thank You to neilmcl For This Useful Post:
BruceVolvo (16-04-2018), pxr5 (16-04-2018)
Old 16-04-2018, 01:14 PM   #7
BruceVolvo
Thanks Neil, I'll get one of these at a £10.00 a lot better the the £33.00 Hoselock and it looks a similar construction.
Old 16-04-2018, 01:22 PM   #8
mawallace
Are any of these anti kink hoses available on a reel - my old Hoselock has seen better days and I am looking to upgrade?
Old 16-04-2018, 01:58 PM   #9
percymon
I swapped my old Hoselock item out for a Claber SilverElegant hose last year - no problems at all using the old Hoselock reel - I would add that the Hoselock connectors are better than the Claber versions, and if i was buying again I'd stump up another £5-10 for the SilverGreen as I find the silver Elegant kinks almost as badly as the 12 year old Hoselock did
Old 16-04-2018, 03:00 PM   #10
BruceVolvo
Bugger No stock at our local Aldi, looks like the Hoselock ultimate, I can get that at on the way home from work.
