Hi all just need some quick advise on koch chemie compounds and polishes.
Used h8 on a megs mf today on my golf r and got a loverly result, left me with little to no marring with all scratches and swirls removed.
I am planning on refining this tomorrow with m2.
The issue I am having is that compared to other compounds and polishes I have used there doesn't seem to be a clear sign that the compound has been broken up ?
Any one had any experiences with this who could offer some advise. ?
All Koch polishes have super long work times. With the M2 02 I would advise just to do a standard section set but on the last 2 or 3 passes just back off on the pressure and increase the speed a notch. You will see the lubrication of the polish weaken. Wipe off and job done. Stand back and smile!!!!:thumb:
Hard to say without seeing the paint. If the H8 has finished down as you say just start of with a couple of each and build up from there if the results are not what you want. Trial and error will help you get an understanding of the polish and what it's doing. :thumb:
Good advice above, as said I usually do around 4-6 passes with H8 then check the results and if I need a bit more polishing then I just carry on bit longer, it's hard to say how much you should do because it depends on how bad or what you are removing, but with M2 it to has a long working time so just do the same as before just with light downward pressure.
cheers chongo, h8 have a great result, had to hit some panels multiple times ! was really hard vw paint and was surprised how little It was taking off. I was doing around 6 passes with h8 which was working nicely.
What pads or pad have you got for M2? And remember to clean your MF cutting pad after every section pass you make and the same with your finishing pad.:thumb:
haha lucky enough to have an air compressor for that and was planning on using white cg hex pads. Am in the market for some new pads so any suggestions are welcome.
once again, thanks for the advise, is the white cg pad the best with m2 or should you go for a green pad ? also any suggestions on a cutting pad for use on the smaller da since megs mf pads are no longer available in the 3' sizing, I have tried the orange cg hex pad but just doesn't feel as good as the megs mf pad. ?
Related Threads
Detailing World Forum
5.8M posts
94.4K members
Since 2005
