Old 18-08-2015, 08:48 PM   #11
Blue
Unless you washed that with sandpaper I'd be astounded if that is wash marring.
What were your polishing steps? As above, I'm thinking it may need more refining?
Blue is offline   Reply With Quote
Old 18-08-2015, 08:52 PM   #12
Clark @ PB
Clark @ PB's Avatar
Looks like either wash marring or marring inflicted from incorrect buffing technique with your microfibre (yes there's a correct way to remove polish residue!).
Clark @ PB is offline   Reply With Quote
The Following 4 Users Say Thank You to Clark @ PB For This Useful Post:
mjn (28-02-2018), siradamrees (19-08-2015), stangalang (19-08-2015), szladob (19-08-2015)
Old 18-08-2015, 09:08 PM   #13
Richard.
Please elaborate!
Not even being sarky, I am genuinely interested.
Richard. is offline   Reply With Quote
Old 18-08-2015, 10:08 PM   #14
lowejackson
lowejackson's Avatar
Was this using a rotary, if so I would suggest the polish was not worked for long enough or too much polish was used.
If on a DA then 3M products are hard work. The blue top is not so bad but the yellow and green are damned hard work. I would suggest the 3M blue pad is not ideal for a DA, perfect for a rotary but too soft with a DA as it is absorbing quite a lot of the polishing orbit
Old 19-08-2015, 11:05 AM   #15
Clark @ PB
Clark @ PB's Avatar
Originally Posted by Richard. View Post
Please elaborate!
This 60 second video we made a while back should explain all
http://www.polishedbliss.co.uk/blog/...60-second-tip/
The Following 5 Users Say Thank You to Clark @ PB For This Useful Post:
AndyN01 (09-03-2018), Cookies (19-08-2015), Deathstar (28-02-2018), Fentum (28-02-2018), mjn (28-02-2018)
Old 19-08-2015, 08:28 PM   #16
stangalang
king of the flexonian
stangalang's Avatar
I am almost certain that will have been caused from the removal of your polish. It will either be too heavy of a hand, trying to remove too much product in one go, or your cloths are either crap, or clogged, or both. Try re refining, use new cloths to buff off, and don't do big sweeps to remove, take little bites at it with a light motion. If it smears, don't panic, flip the cloth after your initial wipe and do it again, just do it gently and in small chunks
mjn (28-02-2018)
Old 28-02-2018, 02:38 PM   #17
mjn
Little update, it was the IPA wipedown which caused the problem.
mjn is offline   Reply With Quote
Old 28-02-2018, 03:03 PM   #18
Gixxer6
How so? Was it the cloth that you used to wipe down?
Old 28-02-2018, 05:50 PM   #19
Benfr16
Benfr16's Avatar
How does the IPA wipe cause this?
Old 28-02-2018, 06:24 PM   #20
stangalang
stangalang's Avatar
Because its so poorly lubricated that if you have a sensitive paint it causes the cloth to Marr. Its even too strong in of itself for some finishes. A quality panel wipe, or something like eraser is far superior
The Following 2 Users Say Thank You to stangalang For This Useful Post:
Benfr16 (04-03-2018), Gixxer6 (01-03-2018)
