Old 01-05-2018, 10:36 PM   #1
euge07
euge07's Avatar
motorbike windscreen
Anyone had any good results machine polishing black plastic windscreen on a motorbike?
Old 02-05-2018, 12:35 AM   #2
tosh
tosh's Avatar
I had to use a 4” pad and some Menzerna back in the day; haven’t done it for a long while though.
Plastic is a lot softer than paint, so any fine polish will do.
Old 02-05-2018, 03:20 AM   #3
SunnyBoi
SunnyBoi's Avatar
+1. Plastic will load up the pad faster than paint so clean the pad often.
SunnyBoi is offline   Reply With Quote
Old 02-05-2018, 08:56 AM   #4
euge07
euge07's Avatar
I'm struggling with it to get a good finish
it is extremely swirled
tried sonax 04-06 on a green hex pad, then upped it to scholl s3 gold on orange pad which cut out alot of the swirls but I cant get them all out, tried a few passes with s40 on white polishing pad as well to try finish but there is still some left
Old 02-05-2018, 09:04 AM   #5
From these 50/50 images, I think you've obtained a good finish, but I think you're after a perfect finish
euge07 (02-05-2018)
Old 02-05-2018, 09:10 AM   #6
euge07
euge07's Avatar
sorry you are right, it is a huge improvement but I'd like it completely swirl free if possible
The Following User Says Thank You to euge07 For This Useful Post:
Andyblue (02-05-2018)
Old 02-05-2018, 09:51 AM   #7
SunnyBoi
SunnyBoi's Avatar
are you using a DA? If yes switch to a rotary. if youre using a rotary, do a final pass at the lowest speed akin to jewelling, that should take care of the marring
Old 02-05-2018, 12:43 PM   #8
euge07
euge07's Avatar
using a da yes, i dont have rotary but have a force drive polisher as well, so maybe switch to a finishing pad and some scholl s40 and use it?
Old 02-05-2018, 04:38 PM   #9
tosh
tosh's Avatar
If you want perfection:
Wet sand with p1500
Polishing pad and polish on a rotary
Then the finest polish you have on the softest pad you have
Rotary is better in this case if possible
If not a rotary, then hand polish for the last step
Basically the same instructions as for plastic headlights.
euge07 (03-05-2018)
