Old 24-05-2018, 05:02 PM   #11
\Rian
\Rian's Avatar
Originally Posted by Ian W View Post
Cheers for that. It would seem this is out of stock just now with the four different nozzles so I've ordered a lance in the correct fitment for now at least. What benefit would the linked setup give though? Totally novice at this btw so please go easy
More flexablity over fitting types, its hard to find accessories for the nilfisk but their are loads with a quick release type fitting
Old 24-05-2018, 05:53 PM   #12
Ian W
Interesting. Are you saying I need more fittings than just a lance then?
Ian W is offline   Reply With Quote
Old 26-05-2018, 07:12 PM   #13
Ian W
Originally Posted by riskypicker View Post
That’s the one I have on both my snowfoam
Lances yes.
I expected it to replace the nozzles at first until the lance arrived and I saw
The bayonet. Just as well as would be cumbersome to have the bottle filled will
Foam / TFR right on the end of the jet wash lance
Doh, it's arrived and it wasn't this one. Looks more like a Gerni fitment on mine so going to order another adapter.
If you're using a Nilfisk guys, double check the fitment against your own PW, don't be lazy like me and look for the answer online!
Old 13-06-2018, 01:39 PM   #14
rob3rto
rob3rto's Avatar
I emailed Nilfisk and the customer service guy said "the Kew/Alto is the correct fitting, just a bit tight" but I'll be damned if Im gonna force it in.
rob3rto is offline   Reply With Quote
Old 16-06-2018, 05:26 PM   #15
bus_ter
Have you found the correct adapter? Was it this one in the end?
bus_ter is offline   Reply With Quote
Old 16-06-2018, 05:29 PM   #16
Ian W
Looks certain to be the Gerni fitment adaptor which I have, but am yet to try. I'd certainly compare your particular washer with the photos of fitments on line.
Old 16-06-2018, 05:32 PM   #17
riskypicker
riskypicker's Avatar
Depends what youre trying to do Ian really.
If its just for a snow foam lance, you dont need the additional quick release adapter.
If youve got other attachments from previous jetwashes what use quick release fitments, then it'll let you use those on the nilfisk which otherwise wouldnt fit.
Old 16-06-2018, 05:33 PM   #18
riskypicker
The snow foam lance with the alto bayonet goes in directly after the trigger, not right on the end
Old 16-06-2018, 05:33 PM   #19
Ian W
Yeah, it was essentially just the snow foam lance for me. First pressure washer so nothing else to 'make' fit as such
Old 16-06-2018, 05:35 PM   #20
Ian W
Yeah, I'd tried that. The alto fitment shown is the wrong one for my pressure washer which is most certainly likely to be the Gerni fitment (directly after the trigger).
