Old 20-03-2014, 05:22 AM   #11
SuperColin
SuperColin's Avatar
Awesome ! That reminds my 18's :-)
I remember spending hours driving my friend's Turbo i.e, funny toy with a good engine but the handling was terrible. Engine 1 - Chassis 0 (OEM), too much power !
SuperColin is offline   Reply With Quote
The Following User Says Thank You to SuperColin For This Useful Post:
garycha (22-07-2014)
Old 20-03-2014, 07:13 AM   #12
Puntoboy
Puntoboy's Avatar
Send a message via MSN to Puntoboy
Nice work Jas. great to see these being restored and the similarities between the Uno and the Punto. I really need to crack on with mine.
Old Fiats handle badly because their chassis were soft not because they were too powerful.
Puntoboy is online now   Reply With Quote
Old 20-03-2014, 07:17 AM   #13
Citromark
Absolutely fantastic work, you will have a little beauty when she's finished.
Mark
Citromark is offline   Reply With Quote
Old 20-03-2014, 07:38 AM   #14
stonejedi
stonejedi's Avatar
Subscribed,it was one of my all time favourite turbo hatches but I ended up backing and buying a Renault 5 GT TURBO.SJ.
Old 20-03-2014, 09:15 AM   #15
jas_racing
jas_racing's Avatar
Finished of the rear window catch & screws (I had to buy M3.5 screws & nuts to replace the rivet pins I'd drilled out then paint 'em satin black) -
Assembled & fitted -
Refurbed front shock top plates fitted -
I also discovered that the new rear hubs that came with the car were wrong as they are non-turbo, so after a bit of searching I found some correct turbo ones & ordered them. *Pic shows non-turbo on the left, turbo (painted up ready to fit) on the right -
I set to work on the rusty & gunky steering rack -
Rack cleaned up & ready for painting (I did also strip, clean & regrease the rack internals but have no photos) -
Painted & reassembled with new rack ends, track rod ends & gaitors -
Rack/gear linkage bracket took a bit of cleaning up and the little swivel cranks were seized solid initially but it all looks good now after a couple of coats of POR-15 then 2 more of Hammerite aerosol -
jas_racing is offline   Reply With Quote
Old 20-03-2014, 09:16 AM   #16
jas_racing
jas_racing's Avatar
Cleaned, rubbed down & painted the servo & steering column -
Also painted the new master cylinder & mated it with the servo -
Caliper carriers/brackets are finished & ready to fit after a rub down & paint (with POR-15) -
Intake pipes rubbed down, primed within an inch of their lives, rubbed down again then treated to 4 coats of 'tough' gloss black -
Very pleased with how these have turned out, given their prominence in the engine bay
I decided that the scuttle panel & pillars needed painting again so did so with satin black then I could fit the windscreen -
Fitted the interior bulkhead insulation panel (steering column/shaft is also fitted in this pic) -
New front brake shields fitted -
Heater box fitted -
Old 20-03-2014, 09:23 AM   #17
jas_racing
jas_racing's Avatar
Finished refurbing the gear linkage:
(Rods & pivot plate are new but painted up for protection)
Starting to look like an Uno inside instead of a bare shell:
A spot of extra protection around the vulnerable areas courtesy of POR-15:
Fished out this juicy OE part from my collection for a trial fitting:
Doors needed sound-deadening (Fat-Mat)...before:
After: (doors shut with a lovely 'thud' now )
Did the rear quarters too (brown stuff is Dinitrol, and lashings of it too!):
Knocked up the relay mod for the 'leccy windows: (one pair for each side)
Fitted:
Fitted new central locking motors:
Window motor fitted, speaker cable added & door loom all neatly wrapped up along with the cables for the c/l motor:
Lots of other little jobs done too, such as applying Dinitrol in every cavity, sill trims fitted and rigid brake pipes fitted.
I also completely changed the +ve and gnd cables for the fuel pump supply (with 14 awg cable) to be sure of a good electrical feed to the pump.
Old 20-03-2014, 09:25 AM   #18
jas_racing
jas_racing's Avatar
Fuel pump cradle fitted:
With cover plate:
Refurbed gear-linkage fitted:
Some interesting mods to the fusebox (for the headlights) by a former owner that I needed to undo then redo properly:
Old 20-03-2014, 09:29 AM   #19
jas_racing
jas_racing's Avatar
Got stuck into the pedal box...the whole thing had been sitting on a garage floor for 15 years or so hence was looking pretty rough, or at least a lot rougher than you'd expect for something that should have spent its life inside a car protected from the elements:
Stripped:
Cleaned up:
All painted & ready to reassemble (with new pedal rubbers):
All back together & ready to refit:
I also sent a bunch of parts off to be bead-blasted:
Some parts haven't done so well over the years:
Painted up the fuel filter holder/bracket:
LOTS more to come!
The Following 2 Users Say Thank You to jas_racing For This Useful Post:
Envy Car Care (15-12-2014), Roggti25th (31-10-2014)
Old 20-03-2014, 10:11 AM   #20
josh263uk
Stunning so far, let see some more
josh263uk is offline   Reply With Quote
