Old 12-10-2018, 08:28 PM   #371
lincolndanny
Originally Posted by Craighightower View Post
.....nice x reg vtr on eBay for 395. Already on a trailer......
no chance
Old 12-10-2018, 10:27 PM   #372
Ben_W
Ben_W's Avatar
Can't you loan the car to the local fire brigade for a few days.....mark.some cut lines, collect a few days later with the roof nearly tucked inside the now roofless shell
The Following User Says Thank You to Ben_W For This Useful Post:
Cookies (04-11-2018)
Old 04-11-2018, 12:46 PM   #373
lincolndanny
Nothing major to report recently on the VTS fleet. My attentions have mainly been on being ready for next Sunday when, touch wood, Matt's 309 GTI will be turning up for some welding.
'98 Mercury
This has now had it's month of fun and is back on SORN. Running it for a month before it's winter hibernation gave me a great opportunity to not only top up my enthusiasm for it, but to also understand what the car needs as it's next major jobs. For now due to the leaky roof situation, it's off on holiday to be stored at Matt's while I have the 309.
I did manage to tick off a couple more WW2 RAF bases before it came off the road though!
RAF Coleby Grange
20181017_141609 by Daniel Whitworth, on Flickr
20181017_141657 by Daniel Whitworth, on Flickr
On the old Runway at RAF Metheringham
20181017_143331 by Daniel Whitworth, on Flickr
20181017_143623 by Daniel Whitworth, on Flickr
Then finally RAF Bardney
20181017_151747 by Daniel Whitworth, on Flickr
Donor Car
I'm itching to get this pulled apart and out of the way! Trouble is I need it "moveable" until the 309 turns up. I have managed to get it running though and it was actually quite easy!
Upon turning the car over you could smell it was getting fuel so popped a plug out, turned it over and there was no spark. Ignition fault. After checking with a multimeter, the coilpack itself wasn't receiving a signal. A couple of things that points to really. Faulty wiring, a fried ecu or a dead crank sensor. Seeing as the crank sensor is just one plug and one 10mm bolt I went for that first.
20181014_161727 by Daniel Whitworth, on Flickr
Well that was certainly easy enough!
20181014_161552 by Daniel Whitworth, on Flickr
As soon as the 309 is safely in the garage, i'll start pulling this apart...
'96 Press car
Nothing to really report on this just yet. As previously mentioned, the power steering has never worked since I've had it, so with access being great due to the front end strip, I thought I'd investigate.
20180903_191248 by Daniel Whitworth, on Flickr
First of all, the loom for the power steering was missing. This has a live feed, an earth and a switched live that kicks in when the engine is running.
20180903_190343 by Daniel Whitworth, on Flickr
Connected up a spare loom I had in the stash, checked the fuses, started it up and...nothing.
The switched live comes from this little green plug and after checking it out with the multimeter, I found that there was no power coming through.
20180903_190126 by Daniel Whitworth, on Flickr
It was at this point I noticed that the single green wire exiting the plug...
20180905_191635 by Daniel Whitworth, on Flickr
turned in to a red wire by the time it exited the conduit.
20180905_191647 by Daniel Whitworth, on Flickr
Further investigating turns up the original burnt out green wiring...
20180905_191818 by Daniel Whitworth, on Flickr
Hmmm where's that red wire going...?
20180905_191655 by Daniel Whitworth, on Flickr
Decided to pop the wing off to trace it and......
20181103_174920 by Daniel Whitworth, on Flickr
20181103_174927 by Daniel Whitworth, on Flickr
20181103_175653 by Daniel Whitworth, on Flickr
20181103_181028 by Daniel Whitworth, on Flickr
20181103_181117 by Daniel Whitworth, on Flickr
Oh look, the original switched feed wire. It's like archaeology this!
20181103_174940 by Daniel Whitworth, on Flickr
This is where the donor car will come in handy fortunately. Each wire is uniquely numbered like so..
20181103_182121 by Daniel Whitworth, on Flickr
So my aim is to repair the loom correctly using the correct wires from the donor car. I've picked some heat shrink up and cut all the damaged stuff out ready to make a start..
20181103_182014 by Daniel Whitworth, on Flickr
It's certainly had a life this car hasn't it?
The Following 5 Users Say Thank You to lincolndanny For This Useful Post:
Ben_W (04-11-2018), Cookies (04-11-2018), JR1982 (04-11-2018), Tuddie (04-11-2018), VeiRoN (04-11-2018)
Old 04-11-2018, 02:02 PM   #374
Ben_W
Ben_W's Avatar
It does certainly appear that way Danny.....
What seems really odd is that someone must have had it apart like you have to replace that wire.....why on earth they just didn't fix it properly in the first place I don't know......
Old 04-11-2018, 02:08 PM   #375
JR1982
JR1982's Avatar
If it’s been used as a track day car, it could of been a quick fix with limited tools which they then forgot about
Old 04-11-2018, 04:36 PM   #376
Henry_b
Henry_b's Avatar
That loom is mental!
Henry_b is offline   Reply With Quote
Old 04-11-2018, 05:27 PM   #377
James_G
Great update Danny.
Interesting that you mention the WW2 airfields as it has reminded me that I learnt to drive at 16 in my mum's Datsun 120Y on what I assume was the perimeter road of RAF Ramsbury, which latterly found fame as a filming location for Doctor Who.
http://www.doctorwholocations.net/lo...msburyairfield
Sadly (or not) the car didn't last much beyond that and I recall driving it to the scrap yard while still on a provisional license.
As for the wiring, I can see how it happens. A friend came over yesterday in his BMW 330Ci to which he had added angel eyes. Lack of a soldering iron meant he'd wired them using scotchlok connectors and insulation tape. It took all my effort to keep quiet and not chastise him for it!
Old 04-11-2018, 08:28 PM   #378
Ben_W
Ben_W's Avatar
There's an old World War 2 airfield just outside Lutterworth Danny, Bittesby. Bruntingthorpe is local too
Bittesby/Bitteswell is now mostly an industrial estate (Magna Park) but there's some bits still there apparently. You could chuck the welding gear in the boot too. You know, just incase you find something locally that might need a bit of welding......you never know, it might lead to discovering the mysterious south Leicestershire biscuit stash.....
Old 08-11-2018, 07:46 PM   #379
Craighightower
https://rover.ebay.com/rover/0/0/0?m...2F323540160400
Nice clean vts on eBay. Don’t think you have a white one...
Craighightower is offline   Reply With Quote
Old 08-11-2018, 10:38 PM   #380
VeiRoN
VeiRoN's Avatar
Not much interesting if no pics of the underside,front arches etc,nowadays all have some rust lurking,never know what to expect so better be safe,just my opinion though.
VeiRoN is offline   Reply With Quote
