Old 30-10-2015, 10:24 PM   #21
jas_racing
jas_racing's Avatar
So, after discovering more corrosion than I'd anticipated I hatched a plan to deal with the minor/surface stuff myself courtesy of POR-15 but leave anything that needs welding to a specialist to do at a later date (prior to the full respray).
A couple more shots of the corroded areas once I finished scraping & exploring:
The grey area in this one is the factory underseal, the black on the left is the underseal I had done in 2010, so it seems they didn't drop the fuel tank to do it
Onto the POR process, the usual Clean > Prep > Paint stages, a few shots after Prep: (love the way the Prep stuff turns the orangy corrosion grey)
Having learnt the hard way in the past just how difficult it is to get POR-15 paint off your skin I was taking no chances:
Two coats of POR-15 paint were applied, took about 3 hours in total rolling around on cold gravel on my back
Finally, two coats of Dinitrol Underbody Wax:
Mechanicals next
jas_racing is offline   Reply With Quote
Old 30-10-2015, 11:03 PM   #22
jas_racing
jas_racing's Avatar
To get started on the mechanicals I sent a pile of parts off to the shot-blaster, several weeks later I got them back but they'd already spent some days outside in the pouring rain by the time I collected them:
After POR Clean & Prep:
Two coats of POR paint:
I decided to replace the bearings in the trailing arms too as these do tend to wear on Coupé's and it's dead easy to do when the arms are already off the car. Old bearings out and inner bore cleaned up ready to accept the new bearing:
New bearing kit (for one side):
Pic of one end when the kit was fitted:
For the rear beam and anti-roll bar I decided to go a different route than POR-15 as this project is more about durability than appearance, and where I work we rather fortuitously have both a galvanising plant and powder-coating line
A reminder of how the rear beam looked when it came off the car:
Beam was shot blasted (sorry no pics of this) then galvanised along with the ARB:
Rear beam after powder-coating and with new uprated mounting bushes fittted:
ARB after powder-coating:
Rear beam with new load-proportioning valve and brake pipes fitted:
Brake pipes are copper-nickel and I had stainless steel brake pipe nuts custom-made as I've spent too much time over the years struggling to undo corroded mild steel/zinc plated ones
New Munroe dampers to go on the rear beam (easier to fit with the beam off the car as the bolt is only accessible through small access holes in the rear chassis rails once the beam is mounted on the car):
Ready to fit:
And finally back on the car:
Not easy to do on your own!
Trailing arm fitted on N/S:
And O/S:
Another shot of the beam in place:
You've probably noticed but all fasteners are new too, mainly stainless steel but odd ones that need to be high-tensile are 12.9 grade mild steel.
ARB is fitted behind the beam in this pic (not that it can be seen!) but this pic was to show the new spring fitted connecting it to the load-proportioning valve:
That's pretty much up to date now, great to be bolting bits back on!
The Following 6 Users Say Thank You to jas_racing For This Useful Post:
cleancar (14-01-2016), IanG (31-10-2015), Kiashuma (31-10-2015), neilb62 (12-09-2018), s70rjw (18-12-2015), slim_boy_fat (31-10-2015)
Old 30-10-2015, 11:19 PM   #23
losi_8_boy
losi_8_boy's Avatar
Amazing attention to detail
losi_8_boy is offline   Reply With Quote
The Following User Says Thank You to losi_8_boy For This Useful Post:
jas_racing (17-12-2015)
Old 31-10-2015, 12:02 AM   #24
Forsh
Forsh's Avatar
Nice mechanicals!
Loving the neat brake lines - did you use a pipe bender?
Old 31-10-2015, 11:13 AM   #25
PootleFlump
PootleFlump's Avatar
This looks like another epic rebuild. I've got a GTV which you'll probably know is based on the same platform and share components, different rear suspension set though.
PootleFlump is offline   Reply With Quote
The Following User Says Thank You to PootleFlump For This Useful Post:
Old 31-10-2015, 11:56 AM   #26
Tuddie
Tuddie's Avatar
Send a message via MSN to Tuddie
I love Fiat Coupes, will defo be keeping an eye on this thread, keep up the good work mate.
Tuddie is offline   Reply With Quote
The Following User Says Thank You to Tuddie For This Useful Post:
Old 31-10-2015, 01:56 PM   #27
IanG
IanG's Avatar
Loved these back in the day when I had a Punto Sporting
Look forward to your updates
IanG is offline   Reply With Quote
The Following User Says Thank You to IanG For This Useful Post:
Old 31-10-2015, 04:27 PM   #28
ibiza55
Lovely jubbly, exceedingly good work.
Old 31-10-2015, 04:32 PM   #29
slim_boy_fat
slim_boy_fat's Avatar
That's a credit to all your hard work!!
The Following User Says Thank You to slim_boy_fat For This Useful Post:
Old 31-10-2015, 06:24 PM   #30
MadOnVaux!
MadOnVaux!'s Avatar
Fantastic work, it'll be better than new when finished
MadOnVaux! is offline   Reply With Quote
The Following User Says Thank You to MadOnVaux! For This Useful Post:
