Just done a bit of practising today with my DA.
Scratched a scrap panel with some sand paper then used a LC HT Polishing Pad with Megs205 there was a slight improvement but not much.
Then tried the same pad with Menzerna 2500 this time there was less evidence of the scratches but they were still visible at certain angles.
So what would you recommend I try next please to remove the scratches completely (if that's possible) I have Menzerna 500 and a few Sonax pads SFX1 to 4 and a LC HT Finishing Pad
Also, once the scratch is improved would I then need to go over it again with a Finishing Pad and Megs 205
Dave.
Couple of things spring to mind. Firstly, what grade of sandpaper did you use and how big was the polishing area. It could well be you need something stronger than 205 but that is one of the main reasons for buying the scrap panel in the first place.
Thanks for your help.
I used some DIY sandpaper D150 fairly fine. The scratches were about 6" long and my work area was less than 18" square.
I take it the Menzerna 2500 is stronger than 205 so wonder if I should now try a better cutting pad with the 2500 before moving to the Menzerma 500.
If from a body shop, it could have been respray which could affect what you our doing. As for pads, try c/guys pads white pad with 2500 or orange pad 2500. Split the panel with masking tape,in half clean the surface as norm, complete as above, if your not happy, try your 500 orange pad then finish with a finishing pad and polish .
D150 sandpaper? I presume this is not the grit size as 150 grit would be super aggressive. Even if it is something like 1500, it would always be worth using finer and finer paper to make the finish better and make life much easier
Chongo - when you say at the end finish with a finishing pad and polish - do you mean finishing pad with Meg's 205 then add polish or finishing pad with polish on and if so what polish would you recommend
Dave
If your happy with your correction, then finish with 205 with a finishing pad like LC/HT, work times came be bit long with 205, but a bit of spray water can help.
Related Threads
Detailing World Forum
5.8M posts
94.2K members
Since 2005
