Old 13-09-2017, 01:21 PM   #201
gardian
I will give it a go tonight, on her car, see what its like.
gardian is offline   Reply With Quote
Old 13-09-2017, 03:12 PM   #202
kinioo
Originally Posted by swiftflo View Post
I use a similar setup except that I have found no need for a pump to the PW. I found that by pushing the hose from the PW direct on to the tap on the butt with no connector of any kind my Karcher PW is perfect, I saw that the typical connector was reduced inside to about 3/16" bore. My water butts are lifted aprox 12" off the ground. When we went onto a water meter roughly 4 years ago this is what I decided to do. As a retired Plumber I soon had this sussed out.
Was thinking of doing this, but wasn't sure if the 'gravity water pressure' on tap will be sufficient for the PW ??
What Karcher do you use??
Thx,
C.
kinioo is offline   Reply With Quote
Old 13-09-2017, 04:03 PM   #203
The way to check this is to test the amount of water flowing into a bucket over a period of 30 seconds or a minute (depending on the flow and the size of your bucket) and compare that to the flow rate for your PW. Also bear in mind that flow rate from a water butt or similar will reduce as the water level drops.
kinioo (15-09-2017)
Old 15-09-2017, 02:02 PM   #204
gardian
Thx,
C.
its only a small one I cannot remeber the model number I have had it about 8 years, i have had this working from one of the 100L butts and it was fine, the pressure from the tap at the bottom of the 210L tank is much higher so cannot foresee any problems with this
The Following User Says Thank You to gardian For This Useful Post:
kinioo (15-09-2017)
Old 16-09-2017, 04:35 PM   #205
Hughie
Rainwater re use
Hi, (I've just posted this on the Scottish section)
I have purchased these 2 from Amazon and have now run a rainwater hose to the front of our house so I am able to connect my pressure washer to the water butt when I want. It's a chea**** solution.
https://www.amazon.co.uk/foam-water-...%20water%20gun
https://www.amazon.co.uk/151652-Heav.../dp/B01LWY1VO8
Hughie is offline   Reply With Quote
Old 29-09-2017, 10:09 AM   #206
michaelb73
Can you post a picture?
I have now solved this. I have used sealant and quality jubilee clips and now no leaks.
I have also now bought a hozelock water pump and have 3 100 litre butts all connected.
Tried for the first time last week and was actually pretty impressed with the pressure from the hose pipe......wasn't much different to the tap and the positive is its free!!
michaelb73 is offline   Reply With Quote
The Following User Says Thank You to michaelb73 For This Useful Post:
Hughie (29-09-2017)
Old 02-10-2017, 10:02 AM   #207
Good stuff Yep if you've got a pump you'll find it's pretty much like mains pressure.
Old 23-10-2017, 09:11 PM   #208
Kenan
Ballpark how much water is needed to clean a car? I was looking at a 110 water butt but unsure if it will be big enough. Have a K4 and normally only rinse, snow foam, rinse, hand wash and rinse again.
Kenan is offline   Reply With Quote
Old 23-10-2017, 10:42 PM   #209
I think you can easily use 150+ litres in a single wash, although equally I'm sure you could manage on 50 or so. I have 2x200l litre butts and don't wash my car every week, but when I do I like to give the arches a good blast out, rinse it down very thoroughly; it's quite a big car as well (family estate).
Old 24-10-2017, 07:10 PM   #210
Kenan
Thanks, 210L it is then. All fitted and now I'm waiting for rain almost as badly as some wanting to do a beading shot...
rain, rainwater, recycled, water, water butt
