| Waxes, Sealants & Paint Protection Sponsored by DODO JUICE Light Fantastic , Banana Armour, Orange Crush, Rainforest Rub, Purple Haze - www.dodojuice.com |
#1 |
Wax and Sealant thicknesses
Continued from a previous thread on thickness of wax layers. Note, I don't make any claims about effectiveness, I am only measuring the thickness!
Thanks to Caledonia, I have a large selection of waxes and also sealants to test, so I have started a new thread. Here are a few results from the last three days. Testing as before, applying coatings to clean 6" silicon wafers. 20 random spots were measured to give some statistical significance to the results. Below I quote the average thickness and the standard deviation (sd). The standard deviation gives an indication of the spread in the results. .................................................. .................................................. .................................................. .................................................. ................. ***** Vintage (4 coats applied at 24 hours intervals) Wax applied with microfibre, hazed and lightly buffed with clean microfibre cloth. Thickness after first application = 25.6 nm; sd = 2.5 nm Thickness after second application = 26.3 nm; sd = 3.2 nm Thickness after third application = 24.9 nm; sd = 1.9 nm Fourth layer applied by hand. Thickness after fourth application = 27.4 nm; sd = 1.7 nm Because of the spread in the results, as given by the standard deviation, you can't read anything into the small differences in thickness. This seems to show, once again, that you can't layer wax. .................................................. .................................................. .................................................. .................................................. ................. Opti-seal This gave me some problems at first, not having used the product before, because of the difficulty in applying a thin enough initial layer to the relatively small 6" wafer (compared to a car panel). First attempts were definitely too thick, giving strong interference fringes on the smooth silicon wafer that changed rather dramatically as the product dried (very slowly). The end results were very patchy. After advice from Caledonia, I then cut down the amount of product to no more than one drop, applied with a 1" square of microfibre cloth. This easily spread over the whole surface of the wafer and dried to a haze-free finish in a few minutes. Again, 20 random spots were measured. Coats applied at 24 hours intervals Thickness after first application = 17.3 nm; sd = 1.2 nm Thickness after second application = 16.6 nm; sd = 1.1 nm Again, no evidence of layering being possible. An even smaller amount applied to a different wafer:- Thickness after first application = 21.9 nm; sd = 2.3 nm .................................................. .................................................. .................................................. .................................................. ................. Z8 This was applied lightly with a 1" square of microfibre cloth but it did not spread evenly over the wafer surface. Whereas the Opti-seal obviously wetted the surface, this almost seemed to be like trying to rub water into the surface. I wasn't too surprised by the results below (as yet, only one layer applied). Thickness after first application = 4.9 nm; sd = 1.4 nm .................................................. .................................................. .................................................. .................................................. ................. Red Mist This product was much more like Opti-seal, wetting the surface and spreading easily. Not easy to wipe off, so maybe too much applied. Thickness after first application = 22.1 nm; sd = 0.7 nm (a very uniform film!) .................................................. .................................................. .................................................. .................................................. ................. |
| The Following 26 Users Say Thank You to FinstP For This Useful Post: | aBBel P155 SW (16-08-2009), agpatel (16-08-2009), badly_dubbed (14-08-2009), blurb (16-08-2009), Boris Vassilief (16-08-2009), caledonia (14-08-2009), chobis (22-09-2009), Dave KG (14-08-2009), Dodo Factory (15-08-2009), DuncanMon (15-08-2009), Gruffs (30-11-2009), irf@n (15-08-2009), jamrowls (15-08-2009), jeroens (30-11-2009), Leonneke (30-08-2009), Lowiepete (18-08-2009), Miguelgomes (26-01-2010), Racer (19-02-2010), Rob Tomlin (29-11-2009), ross-1888 (02-09-2009), Shredder (27-02-2010), Sonic (17-09-2009), stuart1164 (16-08-2009), tfonseca (02-09-2009), turbulenceNL (19-08-2009), vxrmarc (30-08-2009) |
#2 |
been talking about Gordons trip with him all week!
more so on the reflective index, and that wax has a dulling effect and that its impossible to have depth and shine in paint ![]() Davey |
#3 |
Brilliant, really brilliant! Science in action on Detailing World. Great to see such a test being carried out, and interesting results regarding layering, especially of a wax.
Looking forward to reading more of the findings
| The Following User Says Thank You to Dave KG For This Useful Post: | needhampr (30-08-2009) |
#4 |
DW Supporter & Product Reviewer
Location: Defined Details. Airdrie Scotland. Detailing Studio in Glasgow.
Thanks for taking time to meet myself and a very interesting tour of your labs.
I came away with a very good understanding of the technology and research you carry out on a daily basis. During the conversation that follow also gave me a get insight to finding and as you rightly said this has now been proven once again. With regards to layering products. I am also glad the the conversation that I have had with Dave has not gone to waste, and has given us a better insight as to what an LSP does to certain paint finishes. With regard to there initial reflective rating compared the the LSP rating. Once again thanks F. Gordon. |
#5 |
I'm rather liking this project
so developmental elements may be if Red Mist leaves a layer 75% thicker than Z8 yet in my testing i've found them both to give a good six weeks of visable protection, is the product left behind harder wearing in Z8 or could th thickmness be down to the fully cure of the redmist leaving more solid intact etc Thanks again for your time |
#6 | |
but i think the layer thickness of Z8 in this test is only because it wouldnt spread right on the sillicone |
#8 |
DW Long service and reasonable conduct award
Great test. And my arms say thankyou , thankyou thankyou
#9 |
from reading all these tests only benefit of 2 coats would be to make sure you havent missed anywhere thank you for your time and tests very interesting
#10 |
Sealant like Z - Two
Hello there Fin:
I would like to know if you are layering the Zaino Z 2 in one of your tests. Especially because I have read several topics about the Z 2. Some people claim to layer 7 times - 20 times and even 50 and 51 times. I think a sealant is something completly different then a wax. I think it can be layered. But it would be great if you layered them in your tests. Z - two and FK 1000 P for instance. Well, thanks so far. Usefull threads. Holland - Your votes please: 10 - 10 - 10 - 10 - 10 ![]() ![]()
| Thread Tools | |
| Display Modes | |
