Old 05-11-2009, 09:27 AM   #1
williamsclio1
Ford Racing Puma - Underbody Restoration
Ok all the time has started to protect the underside of the car. I hope my updates help others also looking to protect there car for years to come. Open to ideas and suggestions along the way as this is the first time I have attempted a task to this scale.
At lunch time today I had an hour to burn so decided to make a start on the back box, even tho in the next few days I will be removing it fully to seriously tweak.
After coming across the forum peojectpuma I saw Jacko had started selling short stainless steel bars that fit in the Miltec exhaust to make them look similar to the standard exhaust tip so as that arrived first thing this morning I found 5 mins to fit it, took a little tweaking of the bar but with a gentle tap tap with the hammer all is well,
Personal I think it looks fantastic such a little modification but gives it that standard look. He’s currently selling it on ebay if anyone else is interested.
http://cgi.ebay.co.uk/ford-racing-pu...item2557129f37
I’m fortunate enough to have a garage but its not much wider and longer than the car so its very tight for moving however once under the car space is not an issue its just getting under the car that’s the problem.
Ok started by jacking up the car and putting under axle stands
Photos of the rear carriage of the car, the majority of rust is surface however there are areas were its getting worse.
Removed heat shield
Will be replacing as its cracked in the middle and has seen better days.
Photo of the corrosion under the back box heat shield
Photo of the two bolts holding the heat shield in place.
Quick tidy up with a wire brush
Cleaned the bolts up and sprayed in satin black.
More to come tomorrow.
Not to sure on what product to use, but going towards smooth finish black hammerite on this section, any arguments against or for?????
All comments welcome
David
williamsclio1 is offline   Reply With Quote
Old 05-11-2009, 09:28 AM   #2
williamsclio1
Originally Posted by FRP432
Cool, keep it coming mate as I've got to do the same on 432! I'd love to get all the rear suspension rebuilt too but I need to save more bunce for that!
Jim
FRP432
Will do mate, was going to do more this evening but decieded to watch the Liverpool Game, so livid :cry:
Originally Posted by speedline
Mine has been done with Bilt and Hamber products.
yer been reading up on this today and going to buy the following car care pack BILT-HAMBER WINTER CARE KIT
http://www.bilthamber.com/bilthamber-special-offers.php
Ok quick update, after being to the hospital today for my EEG scan it looks as though i wont be able to drive for a year :cry: :cry: :cry: :cry: :cry: :cry: :cry: wont know for sure untill the results come back in a couple of weeks so its not looking good
Absoultley gutted as only had my licence back for less than year as i was bannded for 9 months for drink driving ops: ops:
So as i cant use the car for a year :cry: i have decided that i may as well strip the whole under carriage and really go to town, as well as getting the car to concourse condition over the next 350 days.
Will be having to move the car on to the drive for the extra space for the rear beam, fuel tank suspension etc.
So first things first i need a car cover.
I know i said i would rather not use my car during the winter but i didnt mean for an entire year
A very gutted David
Old 05-11-2009, 09:55 AM   #3
steveo3002
Mr Sparkle
steveo3002's Avatar
Send a message via MSN to steveo3002
id suggest you go alot further with the wirebrushing....keep on at the rust until it comes off and leaves silver metal
a wire wheel in a grinder or drill would be best
skip this stage and you might as well not bother ...you need to remove the rust best you can , not just paint over it and hide it
steveo3002 is offline   Reply With Quote
Old 05-11-2009, 12:32 PM   #4
williamsclio1
Yeh that was just a quick brush on the screw attached to the chassis not started on the rust yet, hopefully be making a good start over the weekend wether permitting.
Old 05-11-2009, 01:39 PM   #5
vaughanmc
vaughanmc's Avatar
Send a message via MSN to vaughanmc
What I'm going to be doing with my Nova Sport is wire-brushing all the underneath until the good metal comes out - Maybe a couple of coats of Etch Primer, a few generous coats of black Stonechip then another few layers of Hammerite Smooth White then the inner panels such as door internals, quarter panels, box sections etc will be done with Waxoyl
Should be good to see how you go about it
vaughanmc is offline   Reply With Quote
Old 05-11-2009, 06:28 PM   #6
williamsclio1
going for the following had some great reviews
Not sure on what paint to use as a final finish and what colour as yet but going to call Bilt - Hamber and se what they recommend, been told there very helpful.
Will keep the updates coming, had intended on doing a lot this weekend but i have a friends BMW to detail so depending on wether etc will depend on what i manage to do.
David
Old 06-11-2009, 01:26 PM   #7
ChrisJD
ChrisJD's Avatar
Sorry to hear you'll not be able to drive for a year.
Good luck on the restoration project, look forward to further updates.
Have you considered painting the underside in the top surface blue?
Chris.
ChrisJD is offline   Reply With Quote
Old 06-11-2009, 01:29 PM   #8
738ALR
738ALR's Avatar
I've used a gel called jenolite before (might be similar to the bilt hamber one), simply brush on, leave for a while and then use a wire brush to remove. Apparently it 'kills' the rust aqnd stops the oxidisation process.
Just my 2p's worth!
738ALR is offline   Reply With Quote
Old 06-11-2009, 01:37 PM   #9
snapsnap
If you have something rusty and it can be immersed, Deox C will blow your mind!
snapsnap is offline   Reply With Quote
Old 07-11-2009, 07:04 PM   #10
williamsclio1
Chris.
Yeh really gutted but nothing i can do about it i suppose
Yeh thinking that would be the best way to go, so then it would be a case of finding a similar match to the body colour in a make which is suitable for underside of the car.
David
The Following User Says Thank You to williamsclio1 For This Useful Post:
