Old 24-11-2006, 09:59 PM   #21
skid
skid's Avatar
Send a message via ICQ to skid
Pity the Blackfire range isnt mentioned in the guides or is just classed the same as the Menzerna?
skid is offline   Reply With Quote
Old 27-03-2007, 11:58 AM   #22
mycleancar
wow lots of info to read
mycleancar is offline   Reply With Quote
Old 30-03-2007, 04:36 PM   #23
Ade
Excellent guide... thanks
Ade is offline   Reply With Quote
Old 20-06-2007, 11:01 AM   #24
Chris20vT
Does anyone have the facility to update this chart? Its really good and the addition of some more products would make it excellent, especially for s.
I'm thinking more Menzerna, JEFFS possibly AG?
Chris20vT is offline   Reply With Quote
Old 21-07-2007, 09:56 AM   #25
blokewithacloak
Guest
Posts: n/a
Only just found this and its very useful, Thanks for putting the info together.
Old 03-08-2007, 08:46 PM   #26
Mark B
Mark B's Avatar
Abrassive chart is excellent but would it be possible to get the AS compounds on ther also please.
Mark B is offline   Reply With Quote
Old 04-08-2007, 01:45 PM   #27
buda
My suggestion in understanding abrasive grits is to buy products that name the grit sizes:
600 grit - extra heavy for use after wet sanding or on a heavily oxidized single stage paint
800 grit - heavy can be used above
1200 grit - medium for single stage and some badly scratched clear coat finishes
1500 grit - light medium - for correction needs between
medium and light grit
2000 grit - light for use on clear coats
Micro Fine grit - for use on spyder scratches on clear coats
The problem you will run into here is trying to get your supplier to provide you ********** information on the grit size in their compounds. If you force the issue they might respond with information. But the chemists use this terminonlogy when selecting abrasives for the compounds.
They use either silica which does not break down as it is used or aluminum oxide which does breakdown as it is being use. But it has a tendency to gum up. So a good compound is one that uses a combination of both silica and aluminum oxide.
Regards
Bud Abraham
buda is offline   Reply With Quote
Old 20-12-2007, 03:46 PM   #28
linepulse
this was very helpful cheers!
linepulse is offline   Reply With Quote
Old 21-12-2007, 07:56 PM   #29
NornIron
NornIron's Avatar
Originally Posted by db_abz View Post
A real question here; is the Menz Final Polish listed on this chart the product called Final Finish PO106FF? If so, where would the Final Finish PO85RD sit on the abrasiveness chart?
These may seem obvious to the more experienced, but I just got a pack of the 4 x 250ml Sample Kit from CYC, in preparation for the G220 which is gift-wrapped somewhere at home
NornIron is offline   Reply With Quote
Old 19-01-2008, 12:18 AM   #30
dazzpowder
Originally Posted by WX51 TXR View Post
Hi Andrew, have a look at the following guide to polishing that appears on my site - it's a bit of a read, but all is explained.
How to safely polish your paint by hand or machine
Thanks WX51 for a great read on your site, you've answered many questions.
dazzpowder is offline   Reply With Quote
The Following User Says Thank You to dazzpowder For This Useful Post:
mark53 (23-06-2015)
