Old 25-11-2010, 06:10 AM   #1
braymond141
braymond141's Avatar
Leatherique Leather "dye"... Discuss what true leather dye is.
I purchased a Leatherique Laguna Seca Blue leather dye kit to do a little two-tone project on my M3. Come to find out, this isn't dye. Without any other information, can the professionals please elaborate on what a dye is, and what this crap is.
The topic of this thread has nothing to do with prep work, or how I got it to peel. I would like to discuss how this product claims to be a dye and clearly does nothing of the sort.
I appreciate all factual help
-Brett
braymond141 is offline   Reply With Quote
Old 25-11-2010, 08:40 AM   #2
judyb
judyb's Avatar
A dye penetrates the leather and soaks in and a pigment (paint) sits on the surface. Dyes can therefore only be used on leather that absorbs (ie without a pigment coating).
Think about it like wood - a stain (which is a dye) soaks in but will not hide the natural characteristics of the wood, a paint will cover the surface and hide any damage.
What you have is a pigment (paint)
Unfortuantely in the USA they do call pigments dyes which just confuses the whole issue!!!!!!!!!!
Hope this helps
judyb is offline   Reply With Quote
Old 25-11-2010, 10:04 AM   #3
derref
For the record, the OP did not correctly prep that piece of leather.
Leatherique calls for a 4 step process (minimum) including dyeing the leather. Using a cleaner to get rid of surface dirt etc, then using a rejuvenator to bring the leather back to life. Then the most important part before dyeing: Using a prepping agent to strip the old (weak) dye from the leather piece. You soak a piece of 1000 grit sandpaper in this prepping agent and wetsand the piece lightly until the weak dye starts coming out. Sanding (with this prepping agent) is to remove the old dye, not to merely promote adhesion by sanding.
The OP failed to do all of these steps and therefore, his dye did not take. Under ideal prep conditions, the dye soaks into the leather and replaces the old dye. It's obviously not as good as vat-dying leather but it's a darn good diy solution for most consumers in the U.S.
Keep this in mind as you answer the OP's question. He did not prep properly. Had he correctly prepped, he would not have been able to merely peel up the dye like that.
It's a water based dye btw.
Here is a photo of all the necessary dyeing components:
http://farm3.static.flickr.com/2662/...45623959_b.jpg
derref is offline   Reply With Quote
Old 25-11-2010, 10:27 AM   #4
braymond141
Neil, you were given the answer as I already told you. I also never discussed the prepping which was done adequately and with all their products
Hope this helps
Thank you so much; that's exactly what I concluded myself.
Old 25-11-2010, 10:29 AM   #5
Hou
Hou's Avatar
Manufacturer?
Love the colour of the blue!
Did the kit come with instructions as mentioned above?
Hou is offline   Reply With Quote
Old 25-11-2010, 10:38 AM   #6
braymond141
Judyb; if you could explain what product would dye leather and give a perfect, factory matte finish, I'd love to know.
The leather in question is BMW Nappa.
Old 25-11-2010, 10:38 AM   #7
braymond141
Originally Posted by Hou View Post
Manufacturer?
That kit manufacturer is Leatherique, same product as mine, just Cinnamon instead of LSB. And my issues were with the product not actually dying, but leaving a "latex" painted finish; that's something that it does regardless of how much Leatherique asks you to sand the leather (with 400grit sand paper mind you).
Old 25-11-2010, 10:50 AM   #8
derref
This is a direct lie. If you had correctly/actually used the prepping agent, your armrest pictures would not be black at all. Prepping agent completely strips the leather of all the old dye. YOU ARE LYING TO EVERYONE HERE
Manufacturer?
Yes. You MUST follow specific prepping instructions which the OP failed to follow
THIS IS A LIE AGAIN. I have dyed properly using leatherique and when you prep the leather correctly, the dye does not act like latex paint at all. It does not just sit on the surface like that. It soaks into the leather like dye should. There are hundreds of documented cases on the net where people have used leatherique products and their dye acts like dye, soaking into the leather. This is because they prepped properly WHICH YOU DIDNT DO.
If anyone wants to see how to properly prep leather products using this leatherique, visit their website:
www.leatherique.com
EDIT: Just to clarify, I'm not in any way affiliated with leatherique. I merely did a huge interior restoration project last year using leatherique products and the OP here is trying to get the answer he wants by providing false information and manipulating you guys.
Here is how leatherique dyes should turn out when used properly: the thread is huge but if you care to read through it...
http://forum.e46fanatics.com/showthread.php?p=11006569
Old 25-11-2010, 10:58 AM   #9
braymond141
Just let them answer the questions Neil. The guys here know a lot more than you or I do and can explain things much better. Don't drag that nonsense thread into this, just provide them with information and let them answer. This is how I found out about Gliptone and learned my lesson over never using Leatherique leather care again.
Old 25-11-2010, 11:02 AM   #10
derref
I don't care if you have it, you didn't use it. If you used it, the leather pictured wouldn't be black AT ALL. As I already said, it's a dye stripper essentially. When you use it CORRECTLY, your leather pieces turn gray
In addition, your leather is still shiny under there. Once you actually sand it with prepping agent, it becomes completely matte. Which it isn't AT ALL.
