Old 05-02-2011, 07:48 PM   #1
angajatul
angajatul's Avatar
Thumbs up DIY Sun Gun - romanian version, cost under 5 GPB!!!
This project started after trying with my friend Razvan aka brautomobile to find a way to have a sun gun similar light at a lower price.
Project and design by Razvan aka brautomobile , engineered by angajatul
You will need :
- a broken hair dryer or a really cheap one
- a 50W halogen bulb
- a socket for the bulb
Tools :
- isolating tape
- cordless drill
- philips screwdriver
- hot glue gun
- a file
- pliers
- cutter
- a small piece of metal or something similar
- a screw 3x10 ( i used a 3x25 since it was the smaller I had)
Time : 30 minutes
So....lets start
I had this broken hairdryer
The bulb
The bulb socket
First thing I did was to remove the front piece of the hairdryer
Take it apart
Remove and cut off the heating unit
Cut the isolation at the end of the wires with a cutter or a special tool like the one in the pic
To get this...
Connect the bulb socket to them for a test
Isolate for safety
Test it....
No back to construction.Put the bulb next to the dryer end to see how much room you have to make for it
Start cutting the grid
Test to see if it fits
In this case the edges needed some refinement...see the red circled part.
I used a file for it
Test again for fitting...
Now you need something to put the bulb socket onto.I used a metal sheet from a rigips profile
Bend it to get the necessary form
Using a cordless drill with a PZ1 bit screw it into place
Put the assembly back inside
I used a hot gun to put it into place but any other easier way you find will do
The front part now
Rewire it
Isolate the wires
Mount the back piece
And voila........
Some pics with Razvan's one in action
angajatul is offline   Reply With Quote
The Following 118 Users Say Thank You to angajatul For This Useful Post:
20vKarlos (13-03-2011), adamck (23-02-2011), ADW (11-09-2012), Aeroandy (18-02-2011), AlexTsinos (05-02-2011), ARman (05-02-2011), azibux1 (06-02-2011), Baracuda (19-02-2011), BareFacedGeek (01-03-2011), BIG BAVARIAN (18-02-2011), Bigbruno71 (07-02-2011), BlueMikey (22-02-2011), buldy (22-02-2011), byrnes (12-02-2011), capri kid (07-02-2011), Car Key (05-02-2011), CAREDLINE (07-11-2012), cheeks (14-02-2011), conor.pharrell (07-02-2011), cotter (08-02-2011), d-rive (22-02-2011), damdam (24-10-2011), Dan Clark (14-02-2011), Danny B (06-02-2011), david_h (01-05-2011), DetailMyCar (06-02-2011), Dodoalan (02-03-2011), Ducky (08-02-2011), DW58 (07-02-2011), Eddy (20-02-2011), Estoril-5 (07-02-2011), fire122 (03-03-2011), FlawlessDetailing (07-02-2011), flying dutchman (08-02-2011), gally (08-02-2011), Gleammachine (14-02-2011), GlenStaff26 (30-03-2011), Goober (27-07-2012), GrantB5 (15-04-2013), grant_evans (20-02-2011), greymda (25-04-2014), Grizzle (07-02-2011), HAWKEY_SKYLINE (11-08-2014), HC1001 (06-02-2011), HGee (26-02-2011), HornetSting (01-03-2011), impster (07-02-2011), isctony (26-02-2011), Jam (23-05-2011), james vti-s (27-05-2013), james_death (06-02-2011), jamie_s (07-02-2011), Jav_R (09-05-2011), Jesse74 (06-02-2011), johnsastra16v (23-05-2014), Judas (22-02-2011), kevepsi (13-02-2011), KevinTheOx (21-02-2011), ksm1985 (19-02-2011), Lancashire (10-05-2011), mad3lin (04-09-2013), magpieV6 (21-02-2011), markito (06-02-2011), Martin_HDI (07-02-2011), MilesBetter (28-02-2011), Millz (28-02-2011), Mini 360 (06-02-2011), Mirror Finish Details (06-02-2011), mislavto (09-03-2011), missyR (11-04-2013), moosh (11-09-2012), mrbloke (15-02-2011), Nally (07-09-2012), Nanoman (05-02-2011), nath69uk (07-02-2011), Nick's CTR (24-02-2011), Niki (09-12-2011), Ninja59 (20-02-2011), nope-mx5 (29-04-2011), o0damo0o (18-02-2011), Ojai (24-02-2011), Oli1983uk (22-02-2011), OrangePeel (19-02-2011), ozy (12-02-2011), P90PTS (22-06-2011), paulmc08 (07-02-2011), pavsingh (18-05-2013), Planet Man (12-02-2011), Powerff (18-11-2013), powersteam (05-11-2011), priceworth (06-02-2011), prokopas (08-02-2011), RandomlySet (06-02-2011), rob750 (06-02-2011), robtech (19-02-2011), rsdan1984 (18-02-2011), Sandmo (28-02-2011), shaqs77 (18-02-2011), Simoni (07-02-2011), skorpios (15-09-2012), slobodank (17-02-2013), spitandpolish (15-11-2015), stewartmak7 (07-02-2011), stonejedi (20-02-2011), Swell.gr (22-02-2011), T.C (12-10-2014), T25DOC (08-02-2011), ted11 (07-09-2012), telewebby (21-02-2011), the_names_james (28-02-2011), tim (06-02-2011), umi000 (02-11-2011), uzi-blue (09-05-2011), wadoryu (06-02-2011), West (21-02-2011), WP-UK (06-11-2011), yamaha (06-02-2011), ZERO (09-02-2011)
Old 05-02-2011, 07:51 PM   #2
james_death
DW's 'Mr. Helpful'
james_death's Avatar
Intresting
The Following User Says Thank You to james_death For This Useful Post:
angajatul (05-02-2011)
Old 05-02-2011, 07:52 PM   #3
ant_s
ant_s's Avatar
Looks pretty impressive, good 50/50 pic showing it works aswel.
ant_s is offline   Reply With Quote
The Following User Says Thank You to ant_s For This Useful Post:
Old 05-02-2011, 07:55 PM   #4
91davidw
91davidw's Avatar
Nice ingenuity there, top marks
David
91davidw is offline   Reply With Quote
The Following User Says Thank You to 91davidw For This Useful Post:
Old 05-02-2011, 07:59 PM   #5
CliveP
Good stuff! Now you need to work out if you can produce them in quantity and ship them to the UK!
Regards,
Clive.
CliveP is offline   Reply With Quote
The Following User Says Thank You to CliveP For This Useful Post:
Old 05-02-2011, 08:01 PM   #6
Jem
Jem's Avatar
That mighty impressive!
Only things I would say is the hot glue is likely to melt, and the wires either side of the bulb holder look very close to the metal strip and could chafe through and short.
Other than that, top work
Jem is offline   Reply With Quote
The Following 4 Users Say Thank You to Jem For This Useful Post:
angajatul (05-02-2011), Derbyshire-stig (05-02-2011), lambchop16v (05-02-2011), Rundie (05-02-2011)
Old 05-02-2011, 08:02 PM   #7
stangalang
king of the flexonian
stangalang's Avatar
Is that the type of bulb in a sun gun. I mean, to the op, great job and many thanks, but if its that easy i dont really need it to look like a sun gun. If that is the type of bulb surely we could all just mock something up and save 400 notes, couldn't we?
angajatul (07-02-2011)
Old 05-02-2011, 08:02 PM   #8
Davemm
Davemm's Avatar
looks good, if only i had the time to do this.
Davemm is offline   Reply With Quote
The Following User Says Thank You to Davemm For This Useful Post:
Old 05-02-2011, 08:08 PM   #9
Derbyshire-stig
Derbyshire-stig's Avatar
Location: Latitude: 52°04'17.37" N Longitude: 1°00'56.54" O
Send a message via MSN to Derbyshire-stig
the heat those bulbs generate will make it fun to use for long periods
Derbyshire-stig is offline   Reply With Quote
The Following User Says Thank You to Derbyshire-stig For This Useful Post:
Old 05-02-2011, 08:10 PM   #10
ant_s
ant_s's Avatar
I did wonder that myself, but i've never looked into the sun guns so nto sure what type of bulb they use.
The Following 2 Users Say Thank You to ant_s For This Useful Post:
angajatul (07-02-2011), FlawlessDetailing (07-02-2011)
