Old 24-11-2017, 03:01 PM   #1191
Croques
Originally Posted by Fentum View Post
£8.08 and no postage from here:
http://www.cheapeststore.top/light-b...n-p-10782.html
I've just ordered so not received yet, but will keep you posted.
Also for those on the Continent or going there on hols - Bricoshop (a French B&Q type chain) is selling a suitable generic 12v rechargeable drill for €19.00.
Peter
If you enter credit card details on this site they are not secure. I
Old 24-11-2017, 07:04 PM   #1192
Fentum
Thanks for the reminder.
No problem with my card since, but the thing never turned up.
Peter
Old 11-02-2018, 11:32 AM   #1193
Itstony
Itstony's Avatar
Thread seems to have died, looks like the bulb issue has hurt?
Just wondered if anyone tried the 20w or 50W 4700K instead of the 35W rip-off cost now?
Old 12-02-2018, 09:22 AM   #1194
valve5425
I bought a couple of these. https://www.thelightbulbshop.co.uk/Decostar51CoolBlue
I've not used the sun gun/bulb, so I've nothing to compare them to, but they do show up the swirls. Just probably not as effective as the correct bulb. They're cheap enough to try though, and might be good enough for what you want.
valve5425 is offline   Reply With Quote
Old 12-02-2018, 10:32 AM   #1195
Itstony
Itstony's Avatar
I found a few 4700k 50w which is neutral, but obviously all got wise and upped the price on 35w. I will try the 50w and it may not be as good, but a tupny-apeny rigup it must worth it.
Hard to argue it wont be when most wouldn't shell out for the real deal at £300+.
Be good to hear if others did the same though.
Old 12-02-2018, 03:09 PM   #1196
Worth a mention - this is still a thing you can buy, and it's brutal at showing up imperfections in paint. It's also built like a tank, and a seriously good flashlight, as well as a very effective lantern when coupled with one of these.
It's not as cheap as a DIY sun gun but I'd argue it's better at paint inspection, and much more useful otherwise....
Old 12-02-2018, 06:15 PM   #1197
Itstony
Itstony's Avatar
Thanks for taking time to reply.
Looks a very good torch indeed. Accepting your views, it does not look so expensive and has other practical uses.
The only caveat for me was/is it is not rechargeable item. There are others that are on that site, did you look at those?.
Old 12-02-2018, 07:41 PM   #1198
Whilst it is not itself rechargeable, the battery life from a set of 4xAA NiMH batteries is very good, plus you can always buy alkaline AAs in any random corner shop in a pinch.
Old 12-02-2018, 07:51 PM   #1199
huxley309
Blf Q8, variable brightness levels 5k lumens good for outdoor use.
https://www.banggood.com/BLF-Q8-4x-X...r_warehouse=CN
But usually it's my Nebo Big Larry
https://www.screwfix.com/p/nebo-nb63...h-3-x-aa/9205v
Old 14-02-2018, 07:57 PM   #1200
Itstony
Itstony's Avatar
[QUOTE=huxley309;5434956]Blf Q8, variable brightness levels 5k lumens good for outdoor use.
https://www.banggood.com/BLF-Q8-4x-X...r_warehouse=CN/QUOTE]
Can you say if you use this for paint inspection and how you rate it? Clearly it can do lots more.
The light temperature is good, bulb reflector is not smooth though. Large bulb head which is good.
Looks promising, will see what you can say about using it., might then order one.
Its not bundles for sure.
